beautiful twins
Old Jul 12, 2006 | 10:41 PM
  #261
parish8's Avatar
single digit dreamer
Originally Posted by James B.
Can you run a separate cable to the main fuse junction and leave the existing one to the starter solenoid? That would make startup voltage loss even less than it was stock. If you do that the ground may need to be increased or doubled up too.
i could but i we just changed a couple of numbers in the tune and it is all better.
i got most of the wireing done tonight. probably finish the wireing tomorrow and the vacume lines and the crank case evac. that wont leave all that much for this weekend
Old Jul 12, 2006 | 11:01 PM
  #262
tt427ls1's Avatar
LS1TECH Sponsor
cant wait to see this thing done. Going to be a nice setup!!
Old Jul 13, 2006 | 12:52 AM
  #263
TURBHOE's Avatar
so when is dyno day??????????
Old Jul 13, 2006 | 01:33 AM
  #264
SBTork's Avatar
......so how many parachutes are you going to have on this truck?
That's one hell of a truck, can't wait to see you break a dyno somewhere.
Old Jul 13, 2006 | 05:12 PM
  #265
parish8's Avatar
if everything works out maybe in a few weeks but i wont be going for any insane new numbers till after drag week(sept).
Old Jul 13, 2006 | 09:56 PM
  #266
74CheyenneSuper's Avatar
twins coming soon >> PICS
i think the twins are here
Old Jul 14, 2006 | 11:55 AM
  #267
duwem's Avatar
Originally Posted by parish8
i would say normal. it came with a batery relocation kit from summit. the starter cranks just fine but there aparenty is a little more voltage drop than i had before and it required a slight tuning change.
you have it in the back of the bed, I assume for weight, but what if you moved it to the front, thats 5 feet less of cable to cause resistance and drop?
Old Jul 14, 2006 | 03:42 PM
  #268
parish8's Avatar
yeah that might reduce the voltage drop but like i said before we just changed the cranking pulse width slightly and it starts and runs great. that problem is taken care of. i put the batery in the back just to make more room up front. the weight transfer of having it in the back wont hurt me either. i am prety sure if you are going to put weight in the back the farthest back you can put it the more it will help with weight transfer.
there was a time when i thought i didn't want weight transfer and just let the front wheels do their job but my thinking now is the more weight transfer there is the better i will hook and 60' even if the front wheels are geting lite. also the front end will be hard to beef up so if i can take some load off of it and let the rear work harder i think i will be better off. beefing up the rear is easy, just kind of expensive.
Old Jul 14, 2006 | 09:05 PM
  #269
hemidup's Avatar
Parish, Will you get everything done this year in time for Drag Week?
Old Jul 14, 2006 | 09:56 PM
  #270
parish8's Avatar
i hope to be done tomorrow or sunday. i got the intercooler pump mounted and all plumbed and wired. i have a leak , the pump has -12 inlet threads, i thought i could just use 3/4" npt and some sealant but that isn't working. i suppose i will have to buy some $20 fittings
