Base tune
I posted in the tuning section, but figured I would here as well. I'm doing a 5.3 -> LQ9 + Radix swap and am in need of a base tune for a "returnless" fuel system that would get me over to the dyno. Can anyone help me out with this? I have already checked the tune repository and it was negative for my setup. Thx.
I was in the same boat as you so I can suggest that you post all needed info. Cam(if stock then state), injector size, tuner (ie. EFI Live, HP Tuner, LS1 Edit etc.) that will be used to tune on the dyno and anything else required.
Understand what you're saying. I have HPTuners and have been tuning mine for a couple years now. I have a Radix tune for a "return" style, '03 and older, fuel system that I can work with. All I am needing is the Injector Flow Rate vs KPA VAC for 42lbers (see below). This will get me over to the dyno where I am having someone else tune it.
This excel file is from RedHardSupra and will let you calculate values for your IFR table. Open it up and put in your injector rated flow rate and your rated fuel rail pressure and that should generate the values you need for your IFR table. It has sheets at the bottom for EFI Live or HPT type layouts.
ARC
57
Feb 21, 2022 10:54 AM
Corvette454l88
Sep 1, 2016 01:24 AM
GMCtrk
Jul 17, 2015 06:39 PM
