Bad Brakes after Turbo Kit almost Killed Me !
Old Sep 21, 2012 | 01:53 PM
2toneblown's Avatar
New PCM.
Old Sep 21, 2012 | 01:58 PM
Nflddog1000's Avatar
I had same problem mine was sensor in wheel bearing
Old Sep 22, 2012 | 09:32 AM
smdusaf's Avatar
same problem here
Old Sep 22, 2012 | 10:11 AM
TG02Z71's Avatar
My brake pedal pressure has been for **** for a ,long long time. Even worse after I hurt my engine. No vacuum is the issue, engine is always just below positive pressure or just above even when cruising especially up grades.
Old Sep 22, 2012 | 08:34 PM
BUTTERB30's Avatar
smoke test yr upper motor if possible and check all yr vacuum lines
Old Sep 22, 2012 | 10:02 PM
GONEB4U's Avatar
10 Second Club
You know I was thinking it is the wheel sensor also because the way the pedal kicks back like the abs is working. I drove the truck all day today and it did it more than 20 times. Its getting very annoying. I just dont know why would the whole truck go crazy if it is just the front hub assembly.
Old Sep 23, 2012 | 10:58 AM
bud8fan's Avatar
my '07 started doing stupid **** like this...couldnt find anything wrong and it was all stock with just a tune...got rid of it.
Old Sep 23, 2012 | 11:18 AM
Pulled the ABS fuse and mine was fine only for dam light
Old Sep 23, 2012 | 01:29 PM
GONEB4U's Avatar
10 Second Club
I'll try pulling the ABS fuse and see if it doesn't do it any more.
Choda
Jan 22, 2026 02:03 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
71ls2
Jul 20, 2015 11:53 PM
76k10chase
Jul 17, 2015 01:48 PM
Cowboy17
Jul 9, 2015 08:22 PM
