Attn Radix Guys Need Help!
Old Sep 9, 2005 | 01:21 AM
onyx's Avatar
14 Second Truck Club
Default Attn Radix Guys Need Help!
for the IAT wires:
does your black wire attach to the close or far wire on your IAT sensor?... or does it matter?
i have P0111 and P0113 codes that are plaguing me.
Old Sep 9, 2005 | 09:58 AM
Mort's Avatar
Cool
The IAT sensor connector I used had two white wires coming off of it so I did not worry about which wire I soldered the back or tan wires to when I moved the sensor location. Seems to work fine.
Old Sep 9, 2005 | 01:06 PM
onyx's Avatar
dang ok. well im wondering if i used to thick of gauge wire when i relocated the IAT sensor. maybe its not getting a proper reading because of that.
Old Sep 9, 2005 | 02:00 PM
BlownChevy's Avatar
blownerator
25 Year Member
hey fudge packer....call me later since you are in the hood, I will fix it the RIGHT way for you.
Old Sep 10, 2005 | 04:05 AM
onyx's Avatar
ho, call me 2morrow.. heh. iim in NORCO!!!! BLAHHH!!!!
Old Nov 27, 2005 | 06:55 PM
Vdrumright's Avatar
So was the thicker gauge wire the problem? I am getting the same code on an install I did. I used a thicker gauge wire also.
Feedback will be appreciated.
Old Nov 27, 2005 | 09:53 PM
vanillagorilla's Avatar
I believe he had that wires mixed up, that is all. It was definatley user error because he's from Nor Cal.
Old Nov 30, 2005 | 11:23 PM
onyx's Avatar
ya, the first time they came up, i had the wires hooked up wrong.. as in not even to the PCM... oops.
the second time i had a bad connection.
did you solder your wires, or use the crush connectors?
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
