Anybody know jack about turbo systems?
Old Jul 31, 2007 | 06:27 PM
wiseshanks's Avatar
Default Anybody know jack about turbo systems?
I've got an STS rear mount turbo kit on my silverado pushing about 9lbs. of boost. My only problem with it is that it isn't great off the line...Anyone have any clue how to build more boost faster? Would wrapping my intake tubing with exhaust wrap help that out? Any suggestions?
Old Jul 31, 2007 | 06:46 PM
Dirty Dave's Avatar
Wrap you're exhaust from the manifolds to th turbo. Repair any exhaust leaks.
Get some high flow cats and install a fifty shot. A 2500 to 3000 stall would help you get out of the hole faster.
Old Jul 31, 2007 | 07:28 PM
WJ MARK's Avatar
Put the turbo up front
Old Jul 31, 2007 | 07:37 PM
8ALTNG's Avatar
buy my low compression 4.8L. It made 541rwhp with a STS on it.....
Old Jul 31, 2007 | 07:57 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Change your converter.
You can also do the syty shuffle on the line to build boost before you leave.
Old Jul 31, 2007 | 08:06 PM
ZO6Ted's Avatar
Stall for sure and wrap.
Old Jul 31, 2007 | 08:44 PM
vanillagorilla's Avatar
Wrap your exhaust tubing and your exhuast tubing only. Wraping the intake will only keep the charge air hot. It's best to leave the intake tubing unwrapped and let it dissipate the heat as best it can.
I see you have a 4.8L, what size turbo are you running? What size A/R? If you have a .81, and a stock converter, then switch to a .68 A/R. You can also add fuel while you're brake boosting. The extra unburnt fuel will help spool the turbine.
Old Jul 31, 2007 | 11:35 PM
tut5079's Avatar
How do you add fuel while brake boosting?
Old Jul 31, 2007 | 11:51 PM
If you have tuning software and you're running a SD tune, then you just fatten up the cells that you're in while brake boosting. It's worked pretty well for me while tooling around and practicing my launches. I haven't tried it at the track yet with slicks though.
Old Aug 1, 2007 | 12:25 AM
tut5079's Avatar
So would you fatten it up in your PE EQ vs RPM table or VE vs RPM vs MAP ?
zblee
63
Jun 10, 2023 01:25 PM
05GMC4.8
Aug 7, 2015 09:55 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
lxcoupe
Jul 21, 2015 02:12 AM
Deceptarado
Jul 8, 2015 05:24 PM
