Any ProCharger guys ever run the HoB DD bracket system?
Old Jan 24, 2014 | 09:52 AM
Superado's Avatar
11 Second Truck Club
Arrow Any ProCharger guys ever run the HoB DD bracket system?
Edit:
Dyno results - pg 8
Tuning update - pg 6
Progress pics added - pg 3
Also, if anyone is interested in getting this set-up as well...please ask for Shaun and tell him that you saw it here.
They are interested in the feedback from you guys and debating on whether to make a complete kit with FMIC piping for the 99-02.
Thanks!
They make one for the TBSS and the 03-06 trucks...not sure what would be different for the 99-02 trucks.
It mounts the ProCharger on the passenger side and uses a dedicated 8-rib from compressor to crank. Factory 6-rib serpentine set-up remains stock.
These guys are located in Lenexa, KS...same as ATI ProCharger...so I can only assume they have a good relationship with each other.
Old Jan 24, 2014 | 10:23 AM
thewrx's Avatar
I run one on the tbss, its a quality setup no flex from the bracket with v2. I have a D1 with 11lbs boost on a 3.53 pulley, you can't really go smaller than a 3.0 without belt slip issues.
Old Jan 24, 2014 | 10:24 AM
03sierraslt's Avatar
Looks cool.. But $1650, ouch.
Old Jan 24, 2014 | 10:38 AM
Superado's Avatar
It does put a dent in the pocket, for sure.
The only other things out there are the ATI Performance Products 8-rib & 10-rib set-ups...they're $1295 and not DD systems.
Thanks for sharing!
Old Jan 24, 2014 | 02:25 PM
Mangled03gmc's Avatar
Baltimore Whore
The pro to this kit is the dedicated belt. You would never have to worry about popping a belt and over heating again, unless you a re running a E water pump. If i had a vehicle sitting I would moc one up..
Old Jan 24, 2014 | 07:08 PM
Superado's Avatar
I've messaged them on a couple of forums and FB but no reply.
Messaged "BoostFreak" here as well...looks like he hasn't been on pt.net in quite a while though.
Just messaged them on their website...maybe I'll hear from them soon.
Old Jan 25, 2014 | 08:35 AM
thewrx's Avatar
You trolled a bunch of old *** threads, just send them a pm or go through fast motosports.
There customer support was never there best quality.
Old Jan 25, 2014 | 01:05 PM
Superado's Avatar
LoL... I just did that on tbss forum because I needed (5) posts to be able to PM the guy @ HoB...been on that forum for years but had zero posts.
I'll give Fast Motorsports a shout as well...thanks!
Old Jan 30, 2014 | 09:00 AM
haulass350's Avatar
what is the website for this place?
Old Jan 30, 2014 | 09:05 AM
Superado's Avatar
house of boost dot com
I heard from Fast Motorsports earlier this week via FB...very informative.
I just received an e-mail from Shaun @ HoB this morning as well...also very informative.
