Another Maggie Owner
Old Mar 1, 2008 | 10:36 AM
blue2003ls's Avatar
Default Another Maggie Owner
Well I just finished my install last week so here are the installed pics.
Still runnung the 3.4" pulley and stock manifolds but I just finished the headers and exhaust so those pics are comming.
Old Mar 1, 2008 | 11:23 AM
03sierraslt's Avatar
Looks good man, so how do you like it. What kinda boost are you seeing with the 3.4 pulley? 6lb or so?
Old Mar 1, 2008 | 11:41 AM
TrickTurbo's Avatar
Truck Sponsor
clean install. The tranny cooler stuff I recommend you put a small flare or rough the tubing and use 2 hose clamps per joint. I have seen over time those come flying off from heat expansion and vibrations.
How much room is between the blower and the cowl on a maggie.?
Old Mar 1, 2008 | 02:29 PM
blue2003ls's Avatar
I like it alot. I saw about 7-7.5 psi with the 3.4 pulley and stock manifolds but I just installed some Bassani mid-length headers and expect it will probably drop down a little. If I can get a tune and slap on the 3.2 I think I'll be set for now as far a mods.
Clearance from the j-tube inlet to the cowl is about an inch from the top to bottom.
Old Mar 1, 2008 | 04:02 PM
Doobie's Avatar
Nice looking install. I'm seeing 6.6lbs of boost using a 3.4" pulley.
I do have LT's on but I don't have the "HH" lobes in my 112.
Enjoy!
Old Mar 1, 2008 | 08:31 PM
supersub's Avatar
Nice!You wont be disapointed.
Old Mar 1, 2008 | 08:45 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Sweet! You're going to have to meet up with us at Sacramento Raceway on the 22nd!
Old Mar 1, 2008 | 09:38 PM
blue2003ls's Avatar
Sounds good. I'll check if I have anything going on. I'm pretty sure if I don't I do now.
SlvrSierra4.8
Oct 7, 2015 09:46 AM
turbo6c3
Oct 5, 2015 06:11 PM
old motorhead
Sep 29, 2015 08:22 PM
