Another Maggie Owner
Well I just finished my install last week so here are the installed pics.
Still runnung the 3.4" pulley and stock manifolds but I just finished the headers and exhaust so those pics are comming.
clean install. The tranny cooler stuff I recommend you put a small flare or rough the tubing and use 2 hose clamps per joint. I have seen over time those come flying off from heat expansion and vibrations.
How much room is between the blower and the cowl on a maggie.?
I like it alot. I saw about 7-7.5 psi with the 3.4 pulley and stock manifolds but I just installed some Bassani mid-length headers and expect it will probably drop down a little. If I can get a tune and slap on the 3.2 I think I'll be set for now as far a mods.
Clearance from the j-tube inlet to the cowl is about an inch from the top to bottom.
SlvrSierra4.8
Oct 7, 2015 09:46 AM
