Aeromotive 340 Pump and e85
Old Apr 24, 2012 | 03:29 PM
03LQ9's Avatar
Default Aeromotive 340 Pump and e85
Hi guys, trying to get my fuel set up situated for the new turbo set up. Will a single in-tank Aeromotive 340 Pump support enough fuel for 450rwhp or maybe up to 500 running e85 ?
The plan is to run around 5-6 psi non ic on my stock LQ9 with just a 212/218 high lift cam. The truck is an 03 with a return system. This will be my first venture with force induction and would like to use e85 for its forgiveness if something is off.
Thanks!
Old Apr 24, 2012 | 03:36 PM
kbracing96's Avatar
Yes, That's plenty of fuel pump for that setup. I single AM340 will support about 60lbs injectors in a return system to 6200 rpm in my experience with it.
Old Apr 24, 2012 | 07:44 PM
SLCviaAK's Avatar
I thought the aero motive 340 pump was NOT compatible with E85. Please, someone correct me if I'm wrong.
Old Apr 24, 2012 | 08:11 PM
Area47's Avatar
SLC is right. it will kill that pump with ethanol.
walbro 400 will be enough
Old Apr 24, 2012 | 08:46 PM
Beatdown Z's Avatar
Laid Back
guess that explains why mine died!
Beatdown Z's Avatar
Laid Back
Is a Bosch 044 ethanol compatible?
Old Apr 24, 2012 | 09:21 PM
slammedsilvy's Avatar
It is compatible, buuuuuuuuuuuuuuuuut....
From their FAQ's
WARNING: If you plan to run E85 fuel you must be prepared to install proper filtration, and maintain it as frequently as every 10 run-hours. If not, Aeromotive does NOT recommend you the use of E85 with the 340 Stealth Fuel Pump. Aeromotive’s new product warranty assures the purchaser their 340 Stealth Pump will be free from defects in material and workmanship for one year from the date of purchase. Fuel pump failure caused by clogged/blocked fuel filters is not the result of any defect in the pump itself, and is not covered under this warranty.
Old Apr 25, 2012 | 12:45 AM
03LQ9's Avatar
So the 340 Pump will handle e85 but will not handle a clogged fuel filter it sounds like ? Aeromotive is probably thinking when the vehicle is switched over to e85 the ethanol will clean the tank and fuel system then clog filter and kill the pump ?
Old Apr 25, 2012 | 02:28 AM
TimDave217's Avatar
i'd go with the walbro 400 also, i also have read around and seen that the 340 doesn't like e85/ isn't compatible with it. i think the walbro is cheaper also IIRC.
Old Apr 25, 2012 | 02:43 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
The same thing will happen with the walbro....
