AC hose with Trick T6 hotside
Old Aug 13, 2019 | 11:08 AM
Vortec350ss's Avatar
Default AC hose with Trick T6 hotside
Hey fellas,
What is everyone doing for an AC Line with a Trick hotside? Are they all custom made? Pics would help!
I have the T6 manifold with a 4" dp, so the factory line is not really a great fit.
Old Aug 13, 2019 | 11:13 AM
Alex.'s Avatar
I made my own when I ran a/c, got my hose and fittings from coldhose. com
Old Aug 13, 2019 | 12:23 PM
randeez's Avatar
Massaged mine back and under wastegate, the stock hose y's off because I have front and rear ac
https://www.performancetrucks.net/fo...4/#post5457514
Old Aug 13, 2019 | 12:50 PM
Atomic's Avatar
I have a gauge for that
Someone said if you flip it it works great I think.
Old Aug 13, 2019 | 01:13 PM
TrickTurbo's Avatar
Truck Sponsor
Hey fellas,
Just bend it over at the accumulator, and st the compressor.
My 03. Fitted a 5” dp line stayed on the truck.
08+ it’s much harder but still workable.
Old Aug 13, 2019 | 01:15 PM
Hmmm... I didnt think of that. I will check it out.
Thanks Rick. I will try that as well. So youre saying run it closer to the valve covers in between the downpipe and the manifold?
Old Aug 15, 2019 | 03:30 PM
Go5.3tt06's Avatar
believe it or not, like you say same thing so I did on mine. IMPOSSIBLE it because of t6 with stage 6 wastegate mount to header in the way, Kinda design off, When I see yours and coolant set up. I bought your ford coolant tank it hit to wastegate. I will picture it. it's more work for me to custom make right which ok with me. But ac line I was surprised yours different than mine.
BlackGMC
Jun 4, 2013 04:51 PM
Choda
May 30, 2013 02:40 PM
UnVmy5.3
Jan 23, 2013 11:26 PM
boostedsl2
Jan 16, 2013 03:39 PM
2ktransam
Oct 15, 2011 04:35 PM
