AC hose with Trick T6 hotside
Hey fellas,
What is everyone doing for an AC Line with a Trick hotside? Are they all custom made? Pics would help!
I have the T6 manifold with a 4" dp, so the factory line is not really a great fit.
Massaged mine back and under wastegate, the stock hose y's off because I have front and rear ac
https://www.performancetrucks.net/fo...4/#post5457514
My 03. Fitted a 5” dp line stayed on the truck.
08+ it’s much harder but still workable.
believe it or not, like you say same thing so I did on mine. IMPOSSIBLE it because of t6 with stage 6 wastegate mount to header in the way, Kinda design off, When I see yours and coolant set up. I bought your ford coolant tank it hit to wastegate. I will picture it. it's more work for me to custom make right which ok with me. But ac line I was surprised yours different than mine.
