'98 up 4.3L Boost Help.
Old Mar 23, 2007 | 07:37 PM
  #21
BTW, the turbo I have is from a 3.8L Volvo Penta Diesel. Its got a small exhaust housing and 72mm compressor wheel and 50 trim.
Old Mar 23, 2007 | 08:19 PM
  #22
firefighter's Avatar
I've thought about putting on the marine intake. About $1000 and comes with 6 injectors and no EGR looks ALOT like whats on there allready.
Old Mar 23, 2007 | 09:32 PM
  #23
Spoolin's Avatar
GFYS and STFU
Originally Posted by philntx
$4,500 to 6,000 for a good complete motor and transmission.
Ya gotta figure $6-700 for the harness, $1000 for stainless longtubes, $600 radiator and fans, $250 for a driveshaft, $250 for an oil pan, or notched front Crossmember, $500 for corvette accessories, $180 for an LS2 water pump, $250 for a good exhaust system installed. Another $1,500 for the miscellaneous parts.
Unless it's done by the owner, there's $ for labor to install.
Of course, you could build your own harness, find some radiator to install, shorten a stock driveshaft, use F-body lS1 Fans, modified 98 F-body exhaust manifolds, etc for a lot less.
The costs for these installs will vary greatly.
A takeout LQ9 with a Magnuson will be in the $7-8000 range.
Throw in a $2,500 transmission to handle the 480 HP and torque made by the motor/blower combo.
I second that! I can't imagine you spending more than $7,000-$8,000 for a 400HP DD. taking in of course that you'll recoup a grand or so from the sell of your old parts and do a little of the work yourself.
I love how this forum will not allow you to mod-up your 4.3!! But for good reason too, it's much cheaper and easier to swap out.
Old Mar 24, 2007 | 08:38 PM
  #24
I think I might look hard at a 5.3L aluminum block motor.......
Old Mar 25, 2007 | 10:20 AM
  #25
NegraRCSB2X4auto's Avatar
if your like me. Do what you really want to do because in the end you'll regret it. Take your time save money and do what you want. Because i've done somethings because it cost less but then i'm like damn I wonder what it would of been like if i would have...........So screw that and do what you want.I've went back and sept that money in the end to get what i wanted to begin with that cost more. Just do it the first time.Plan it rethink it and change that all you want but get it right and do it once.
Old Mar 25, 2007 | 10:28 AM
  #26
V2 4.3 S10's Avatar
Hello, guys. Jess here.
take a look at my setup. it was a work in progress since about 2000. i bought it new in 97, has 14,800 miles on it now. it has a lot of mods, too many to list. but basicly (sides what you see) = ported heads, beehives, pro-mag rockers, ahr270 cam, 3.73 posi, converter, edelbrock tes & 3 1/2" exhaust.
the engine pics are kinda old, its even better now. and i have HOOKER SUPER COMP 1 5/8" LT's with true duals and cutouts that are going in.
firefighter
my recomendation. do a rear mount turbo, fmu, and a tune. you will be happy with that, for the money and effort you have into it. no, it won't be the fastest around. but for the money it will be plenty fun to drive.
Frank, hows it goin. your in VEGAS now ?
Attached Thumbnails '98 up 4.3L Boost Help.-dcp01636.jpg   '98 up 4.3L Boost Help.-dcp01640.jpg   '98 up 4.3L Boost Help.-dcp02135.jpg   '98 up 4.3L Boost Help.-dcp02134.jpg   '98 up 4.3L Boost Help.-engine-3.jpg
Old Mar 26, 2007 | 11:28 AM
  #27
If I stay with the 4.3L it's gonna be with a roots style SC I wanna get rid of the factory injector set up.
Old Mar 26, 2007 | 05:27 PM
  #28
Dogsofjune's Avatar
If you do decide to go that route, look up Rat from the link in post #5. He's working on that kind of project and is pretty knowledgeable.
Old Mar 26, 2007 | 06:01 PM
  #29
yeah I talked to him I'm gonna keep asking him questions if I go that way.
Old Mar 26, 2007 | 08:12 PM
  #30
V2 4.3 S10's Avatar
a roots can be done. if i was to do it, i would HEAVILY modifly the stock manifold to look much like a regular roots manifold, except taller. so that real injectors could sit under the blower. but that may make it come through the hood. which may not be a bad thing.
can you weld aluminum ? if so, its just a matter of getting the parts and doing it.
