90mm TB on radix
Old May 25, 2008 | 10:12 PM
turboescalade's Avatar
Default 90mm TB on radix
I went back home and installed my new 90mm LS2 TB on my radix 112 the other day.. I got one of those adapter harnesses and rigged it all up. When I clicked the starter to the on position the TB blade flaps a couple times then stops.. and when I started my truck it says something like decrease power or something.. can't remember.. I didn't think that I would have to retune my truck just for the TB... Do you guys know what I gotta do??
Old May 25, 2008 | 11:32 PM
terravast4's Avatar
You should not have to re-tune for the change over from what I understand. What wire harness did you use and what kind of throttle body did you use? Is it a 6 pin or a 8 pin?
Old May 25, 2008 | 11:38 PM
AFI Performance's Avatar
I had a customer chasing that EXACT same problem for probably 7 months on a retro-install of an LS engine into an older car. He sent his wiring harness back for insepction, had the tune re-checked a couple of times, and it ended up being a faulty T-body.
Not saying that is the for sure issue, but it is exactly the same problem as he had. Changed the T-body out, and it worked perfectly.
Old May 26, 2008 | 08:16 AM
DrX's Avatar
DrX
You might have to swap a couple of wires on that 3-way adapter harness if it was made for a car. Contact Stoichiometric on here. He had the same issue with his setup.
Old May 26, 2008 | 08:27 AM
leftcoast32's Avatar
FormerVendor
There are also 2 different versions of the 90mm Throttle Body, make sure to use the Car Type LS2/7. The other thing is I have seen great results with the new series X module from above for full blade movement.
Old May 26, 2008 | 10:28 AM
BlownChevy's Avatar
blownerator
25 Year Member
Old May 27, 2008 | 09:21 AM
alright.. thanx for all the feedback, I'm not sure whether or not it is the car throttle body or not.. but I will try and use that wiring diagram that stoich. gave me to see if that works
SS94S10
Jan 3, 2019 01:57 PM
natejk
Nov 15, 2016 08:05 AM
Wolftrk99
Oct 2, 2015 08:17 AM
Chevy305
Sep 28, 2015 09:21 PM
bagged7104SS
Sep 24, 2015 08:42 PM
