90mm J tube on Radix question
Old May 21, 2013 | 08:44 PM
beastmode's Avatar
Import Moderator
Default 90mm J tube on Radix question
For those that have swapped out their MP112 J tubes for a MP122 (90mm) J tube. The MP112 tube has 5 usable bolt holes (3 across the top, 2 on the bottom) whereas the MP122 tube doesn't have the middle top bolt hole... did you guys just go with the 4 bolts?
Also, torque specs for these bolts?
tia
Old May 21, 2013 | 08:49 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Yes, just the 4 bolts is enough. I just tightened them until my wrist clicked using my little 1/4" drive ratchet.
This is what I use for sealant back there, just a thin coating is all you need.
Old May 21, 2013 | 08:54 PM
beastmode's Avatar
Import Moderator
Excellent! Thanks a bunch Roger, that pic look familiar?
Old May 21, 2013 | 09:09 PM
1bad2k's Avatar
You can also use loc tite form a gasket. I think the torque needed is about 18ft/lbs.... I only know bc I just did the same upgrade LOL.
Old May 21, 2013 | 09:28 PM
TX Tahoe Z71's Avatar
What was the SOTP difference? I've been back and forth on this mod as I have heard mixed results.
Beastmode, in for your impressions when you get it swapped
Old May 22, 2013 | 12:58 AM
Well, I wasn't going to say anything, but.........
Old May 22, 2013 | 01:00 AM
It is definately a worthwhile & noticable improvement. Part throttle and WOT are both better.
Old May 22, 2013 | 05:17 AM
beastmode's Avatar
Import Moderator
Unfortunately I won't have a before and after impression as this MP122 tube is going on a brand new kit. Figure it's probably easiest to do it right now while the supercharger was sitting on the work bench
Old May 22, 2013 | 10:15 AM
travieso's Avatar
where are you guys getting the 90MM J-tube at ?
Old May 22, 2013 | 10:20 AM
1bad2k's Avatar
Same here man. I am installing the ls6 motor and the mp 112 for the first time this week. Just wanted to get it on before the blower went on.
