90mm J tube on Radix question
For those that have swapped out their MP112 J tubes for a MP122 (90mm) J tube. The MP112 tube has 5 usable bolt holes (3 across the top, 2 on the bottom) whereas the MP122 tube doesn't have the middle top bolt hole... did you guys just go with the 4 bolts?
Also, torque specs for these bolts? tia http://i557.photobucket.com/albums/s...f/686d8578.jpg |
1 Attachment(s)
Yes, just the 4 bolts is enough. I just tightened them until my wrist clicked using my little 1/4" drive ratchet. :D
This is what I use for sealant back there, just a thin coating is all you need. Attachment 115692 |
Excellent! Thanks a bunch Roger, that pic look familiar? :P
You can also use loc tite form a gasket. I think the torque needed is about 18ft/lbs.... I only know bc I just did the same upgrade LOL.
Originally Posted by 1bad2k
(Post 5105924)
Beastmode, in for your impressions when you get it swapped :) |
Originally Posted by beastmode
(Post 5105920)
Originally Posted by TX Tahoe Z71
(Post 5105932)
What was the SOTP difference? I've been back and forth on this mod as I have heard mixed results.
1 Attachment(s)
(Post 5105932)
Attachment 115675 |
where are you guys getting the 90MM J-tube at ?
(Post 5105932)
