8 rib pulleys
My dad has been a tool/die maker for 30 years, and it just hit me when I was getting sticker shock from the price tag of 8 rib pulley sets, that I could have him cut me some of the new pulleys. I need some questions answered first. What material should I have him use, aluminum, or steel. Are the extra ribs cut from the center out, or are they offset in or out. If I get an overdrive crank pulley, can I have him oversize the other pulleys 10%, so I am not overdriving my alternator, and power steering, or should I just leave them alone. Should I just buy the idler, and tensioner pulleys, or could I get some heavy duty bearings to put in that would be better than what comes in anything else.
The ls platform is not just a larger pulley down low, the pulley is the balancer as well. Things cost coin for a reason and I think this part is a big one.
Why are you looking at an 8 rib set up?
Since your building your own pulleys, the offset or from center does not matter. What I mean by this is you will make all your pulleys match up. If it was me, I would leave all measurements ( offsets ) the same as stock and add the extra ribs forward. Material steel will live longer then alluminum unless you hard anodized the alluminum.
Sorry I should have been more specific, I know I will have to buy the balancer/pulley, I planned on an inovators west one of those. I was wondering about making the rest of them match that.
I am getting ready for a tvs 2300, and am being told by everyone that the belt will slip around 10#, and I plan on going way past that.
Never mind, a 10 rib damper is as much as an 8 rib conversion.
I know that it is for high performance, but how can they do that, its only 2 more ribs.
But back to the 8 rib, does anyone have a damper laying around they could measure the difference for me.
What about stainless steel, this is what my dad made as a suggestion, since mild steel would rust fast.
Vortec350ss
Jan 12, 2016 10:36 PM
