70mm Z71 w Trick Stage 2 dyno
I guessing that was done in 2nd gear? Doesnt sound like there was much of a load on the dyno.
In any case those are pretty good numbers for 5psi
Figuring 20hp per PSI you would be right at 400hp at 6psi, around 450hp at 8psi, and around 500hp at 10psi!!!
+110hp and +116ft/lb = Awesome gains man! That just goes to show that the 20hp per PSI theory is pretty accurate.
Im happy for ya man
..... Now I need to get mine done
Im happy for ya man
Inertia Dyno doesn't drag a load on rollers, it's essentially a large heavy free spinning drum and their software measures acceleration of the drum. The brake slows everything down at the end of the run.
Correct johnmaster. I am keeping my dynos the same. 2nd gear 45mph to redline. That way it's apples to apples on each pass.
If I can off my car soon, I'll be aiming for that 500 mark before the fall
