70mm Z71 w Trick Stage 2 dyno
Old Jun 25, 2012 | 10:17 AM
ak2007r6's Avatar
That thing spools up quick. Sounds good and nice numbers!
Old Jun 25, 2012 | 10:19 AM
ak2007r6's Avatar
Originally Posted by black00chev
+110hp and +116ft/lb = Awesome gains man! That just goes to show that the 20hp per PSI theory is pretty accurate.
Im happy for ya man ..... Now I need to get mine done .
hmm.. ""does quick match on future plans"".
Old Jun 25, 2012 | 10:41 AM
fortplainman's Avatar
nice man! 5psi is all you can do with your fuel pump and injectors right?
Old Jun 25, 2012 | 11:16 AM
Choda's Avatar
Injectors will need to be upgraded.
Pump don't know. My tuner said 500 is fine w the flex pump and a hot wire kit. I might play it safe and get a better pump and the wire kit.
Do it once, do it right.
Old Jun 25, 2012 | 01:37 PM
franko98's Avatar
Can't wait to get my kit on
Old Jun 25, 2012 | 02:47 PM
holley2346's Avatar
Flex fuel pump will take you a long ways!
Old Jun 25, 2012 | 02:59 PM
black00chev's Avatar
Slowest turbo build ever!
Its pretty accurate! And if you use the formula to calculate airflow of your engine with boost (plotting PR vs LB/MIN on a compressor map) it will give you a rough idea on what HP you will make.
Like for example, 5.3 (figured 85% VE of engine only) with a max of 6k RPM and 8psi boost it comes out to about 52-53lb/min of air flow which should be close to 525hp at the crank. So figure another 20% off that for drive train loss and you get around 425-450hp at the wheels. And those are conservative numbers.
Old Jun 25, 2012 | 03:49 PM
Choda's Avatar
with the hot wire kit??? right???
im reading a lot of guys using the wire kit instead of a boost a pump.
if they will both support 500 then the hot wires im going with... its nice and clean. less to go wrong right?
Old Jun 25, 2012 | 03:52 PM
ak2007r6's Avatar
still using the flex fuel pump on my truck, will see how it holds up after the new mods. Might go with a boost a pump just for safety.
what is the hot wire kit? Haven't heard of that yet
Old Jun 25, 2012 | 08:25 PM
that was your dyno right? when we throwing a 100shot on my truck and seeing what numbers it throws? lol.
