70mm Z71 w Trick Stage 2 dyno
Old 06-24-2012, 08:43 PM
Choda's Avatar
Thumbs up 70mm Z71 w Trick Stage 2 dyno
2009 ext cab 4x4
Stock 5.3 w 5 psi
376hp. 411tq
Old 06-24-2012, 08:45 PM
03sierraslt's Avatar
Nice #'s for 5psi.
Old 06-24-2012, 09:01 PM
ltr450ryder's Avatar
Sounded badass nice numbers!
Old 06-24-2012, 09:30 PM
Slowest turbo build ever!
black00chev's Avatar
I guessing that was done in 2nd gear? Doesnt sound like there was much of a load on the dyno.
In any case those are pretty good numbers for 5psi .
Figuring 20hp per PSI you would be right at 400hp at 6psi, around 450hp at 8psi, and around 500hp at 10psi!!!
Old 06-24-2012, 09:45 PM
slammedsilvy's Avatar
Nice numbers! About 120 to the wheels gained from 5 psi.
I bet it responds even more once you really put some pressure through it.
Old 06-24-2012, 09:49 PM
Choda's Avatar
Yes 2nd gear. Stock the truck made 266hp and 295tq
Great kit Rick and great tune New Era!
Old 06-24-2012, 10:11 PM
Truck Sponsor
TrickTurbo's Avatar
Sounds peppy.
your welcome. Glad u like the kit.
Old 06-24-2012, 10:18 PM
+110hp and +116ft/lb = Awesome gains man! That just goes to show that the 20hp per PSI theory is pretty accurate.
Im happy for ya man ..... Now I need to get mine done .
Old 06-24-2012, 10:32 PM
MASS seller approved
Johnmaster's Avatar
Inertia Dyno doesn't drag a load on rollers, it's essentially a large heavy free spinning drum and their software measures acceleration of the drum. The brake slows everything down at the end of the run.
Old 06-25-2012, 10:06 AM
Choda's Avatar
Correct johnmaster. I am keeping my dynos the same. 2nd gear 45mph to redline. That way it's apples to apples on each pass.
If I can off my car soon, I'll be aiming for that 500 mark before the fall
Quick Reply: 70mm Z71 w Trick Stage 2 dyno
