6.2 turbo build
Old Nov 9, 2014 | 07:56 PM
  #581
blownescalade62's Avatar
Looks really good Mark! You still on the single 450 pump? What you psi you running now on her?
Old Nov 9, 2014 | 08:10 PM
  #582
Byrdman11's Avatar
Yes still on the single 450. I'm going up to 20lb of boost if the fuel system hold on. Hope to meth push me into the 1000rwhp. Changing to 100% meth soon.
Old Nov 9, 2014 | 08:52 PM
  #583
Wow I would think you would be out of pump by now! If you run 100% meth you should be ok. What you running now 15-16psi?
Old Nov 9, 2014 | 09:44 PM
  #584
Byrdman11's Avatar
5lb boost is all the tires can stand on the street. But if I turn on the CO2 15lb of boost is Nasty. I'm tuning now so hope I can put it on the dyno for some numbers.
Old Nov 9, 2014 | 09:58 PM
  #585
5psi all the tires can handle wow. Get some dyno numbers on her.
Old Nov 10, 2014 | 08:15 PM
  #586
Byrdman11's Avatar
Guys today I wanted to see how the truck would come up on boost. Well I got on the foot brake hard and start pushing the throttle, remember I have a 3000 converter. Up came the rpm and the boost goes wild!! I have the launch control set to 8lb and it hit 8lb easy. The 111m turbine spool up great with the 402ci I'm really excited about getting this setup on the rollers.
Old Nov 11, 2014 | 08:57 PM
  #587
Byrdman11's Avatar
Guys wish me luck. Engines got 325miles on it and got fresh red line oil. I'm putting the Beast on the rollers tomorrow. Not planning to break any records but looking to test some meth and see what it doing on 15lb or so.
Old Nov 11, 2014 | 09:31 PM
  #588
Good luck Mark get a good video of the dyno.
Old Nov 12, 2014 | 03:17 PM
  #589
Choda's Avatar
Good luck man
Old Nov 12, 2014 | 04:00 PM
  #590
Brazos_Speed's Avatar
Good luck. Very nice build!
