6.2 turbo build
Old Oct 31, 2013 | 05:54 PM
  #251
Byrdman11's Avatar
6.2 turbo build-img_1150.jpgGuys the truck did great on the roller today. 742plus rwhp at 13lb of boost. And that with 93oct fuel with meth and the stock exhaust with a dynomax muffler only. The 6 speed trans is hard the dyno too. I think with a 4L80E it will go close to 800rwhp at 13lb. The beast is still getting good gas mileage. Look forward to more tunning, more boost and new trans. Its a rocket!!!! All this was with the stock fuel rails and lines. Just a walbro 450 pump.
Old Oct 31, 2013 | 06:08 PM
  #252
TIM Z's Avatar
11 sec. Truck Mod
Wow that's awesome damn ! Congrats !
I may have missed it but what is done to the 6 speed ?
Old Oct 31, 2013 | 06:24 PM
  #253
Byrdman11's Avatar
This is a stock 6 speed with a 3000 stall and it don't like it. The truck goes threw the gear so fast the trans cant shift fast enough. Im look for trans ideas but mostly think the 6speed is coming out and 4L80E going in.. I will turn it back to 600plus something the 6 speed like better.
Old Oct 31, 2013 | 06:46 PM
  #254
Vortec350ss's Avatar
Holy ****!! You aint kidding its a rocket...
What if you just program it to shift really early WOT 1-2 to eliminate hitting the rev limit?
Old Oct 31, 2013 | 06:59 PM
  #255
Byrdman11's Avatar
I did that and it still wont shift. I thinking I will turn off the factory Rev limiter and install the MSD 2 step Rev limiter and move the Rev limiter to like 6800. I have the limiter set at 6600 and it uses the throttle to controller RPM. Guys I just was thinking I forgot to pull the ABS fuses. That maybe cause a problem too. This weekend I will do more testing.
Old Oct 31, 2013 | 08:24 PM
  #256
TrickTurbo's Avatar
Truck Sponsor
ABS fuses what does that do for you?
Killer numbers and 20mpg.
What about 6L90. A customer mentioned to me.
Old Oct 31, 2013 | 09:20 PM
  #257
Byrdman11's Avatar
Rick, the traction control system still kick in if the button to turn it off is pressed. I do it at the track so I can do a burn out. And the 6l90 is a big difference from what I heard. I checking on a 4l80e and what it take to install it.
Old Oct 31, 2013 | 09:40 PM
  #258
ak2007r6's Avatar
This makes me wish I put that pump on my truck before getting rid of it..
Congrats on the numbers man, that's awesome
Old Oct 31, 2013 | 09:45 PM
  #259
Byrdman11's Avatar
Thanks cant wait to run it. I know I will have to dial it back but still should
haul a$$.
Old Oct 31, 2013 | 09:48 PM
  #260
GMCSIERRA5.3's Avatar
I would go with a 4l80 over 6l80/90 wanting to do the swap on mine later but cant find any info on what wiring to use etc hopefully someone makes the swap and posts info
