6.0,whipple, no electronics!
Old Feb 18, 2010 | 05:28 PM
1slot/a408's Avatar
Default 6.0,whipple, no electronics!
i have a 6.0 lq4 with stock heads . and i want to install a whipple supercharger but without the whipple electronics. i plan on running 42 lb injectors. and need reccomandations on a regulator and fuel pump. the engine will be goin in a 64 chevy pick up.. i have a harness i bought from summit. and the trans will be a 4l6oe semi built. please any advise
Old Feb 18, 2010 | 05:35 PM
blownss06's Avatar
What electronics does the whipple come with. I don't know any blower that brings electronics. If your talking about the injectors and maf then you'll need to run a pcm. I might be wrong.
Old Feb 18, 2010 | 05:55 PM
454SuperSport's Avatar
i think he is reffering to the piggyback computer that comes with the whipple to run the aux. injectors. what harness did you buy and what pcm are you planning to use?
Old Feb 18, 2010 | 06:08 PM
blownss06's Avatar
I thought whipple did away with that.
Old Feb 18, 2010 | 06:12 PM
i'm assuming he is going to use the sidemount style like the one i have, which all came with a piggyback computer.
Old Feb 18, 2010 | 08:28 PM
MikeGyver's Avatar
A Bosch 044 will be sufficient, if you sump your tank that would be to your advantage. The stock regulator is fine if your setup has it.
It will run OK, but if you can figure out a way to intercool it, or spray alcohol, it will run great.
Old Feb 18, 2010 | 09:21 PM
1989k1500's Avatar
If your doing the motor swap I would do a good fuel system in case you want to upgrade later. Get an Aeromotive A1000 or a Magnafuel pump. IMO
Old Feb 21, 2010 | 06:39 PM
1slot/a408's Avatar
yea it is a sidemount whipple. i had it on a 5.3 but decided a 6.0 will be good. the harness i bought dont remember the model but it also controls the transmission. i will be using the stock computer and either gettin a mailorder tune or shop. i will be using the stock cam and stock heads. the electronics i am reffering too it controls the aux injectors
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Lthompson
Oct 2, 2015 12:45 AM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 04:22 PM
