5.3 spits the bit, now what?
Old Nov 25, 2007 | 08:45 AM
stock48's Avatar
9 Second Truck Club
Originally Posted by old motorhead
Is there any advantage going to the 6.0? I think my blower will be about maxed trying to satisify 5.7. Am I about at the limit of what the 112 will feed effeciently? I've been told that I can make a little more boost, but a whole lot more heat by going with a smaller pulley.
My son has a bored out 5.3 (to 5.7) with a Trick turbo setup that's running too good. Just got it back from the tranny shop. Twisted the output shaft in two (on just 6psi).
Either way should work well. The 5.3 I was going to bore out to 5.7 was on the thin side when I had it sonic tested. I must have had a rare thin casting? That's just how my luck goes though. How high was your boost when you hurt your engine?
Old Nov 25, 2007 | 11:12 AM
old motorhead's Avatar
It gets to 9psi pretty quick and holds it. I'm sure it was that high.
Old Nov 27, 2007 | 06:52 PM
Default Update....
Pulled the passenger side valve cover off today. Turns out the #8 intake valve spring was broken. The keepers are gone and the valve is lodged halfway down in the guide. I'm sure it has a nice bend in it. Probably contacted the piston and head in an awkward manner. Another victim of Comp Cams 918 valve springs. I wonder how many engines those springs have trashed.
Raggedz71
Jul 29, 2016 10:20 AM
FlowmasterMufflers
Oct 26, 2015 06:19 PM
FlowmasterMufflers
Aug 17, 2015 04:44 PM
FlowmasterMufflers
Jul 22, 2015 12:47 PM
Mzay
Jul 6, 2015 11:03 PM
