5.3 radix build
Old Oct 2, 2015 | 02:24 PM
  #31
ezdaar's Avatar
nitrous plate instead of that spacer would make more power with cooler IAT's
Just sayin..
Old Oct 2, 2015 | 03:01 PM
  #32
Y-B-Slow's Avatar
Originally Posted by TX Tahoe Z71
Very interested to see results too. I've read the 90mm throttle body is worth 20-30rwhp alone.
I've read about similar gains but I'm skeptical that the throttle body and j-tube alone would net 30hp
Originally Posted by gammey4
Where did you find a 90mm j tube? I've been looking for one for my truck. And which injectors ended up being right? I've got 42's and want to get some 80's.
I bought the j-tube from superchargers online and I know there were only a few left at the time. The injectors are 60# Delphi 11180625, plug n play
Old Oct 2, 2015 | 03:07 PM
  #33
Y-B-Slow's Avatar
Originally Posted by terravast4
$500 isn't bad if it gets the results I've heard of.. the last time i dynoed it i had some issues. it only put down 436hp but later i realized the intercooler pump was bad and for some reason we couldn't get it to dyno i 3rd. I'm not really sure how much power i lost without the intercooler pump but the iats rose so fast it lost power almost right away.
That's a bummer about the pump, I'm sure the number would have been higher if you could have kept things cool. My tuner seems to not really like the idea of 3rd gear pulls. Did you ever end up adding meth? and if so which kit did you use / how do you like it?
Originally Posted by GRRR65GTO
Kinda off topic but I didnt see this thread last year... I live in Medway im surprised we've never crossed paths before
Funny I'm from Franklin, currently living in Bellingham.
Just sayin..
It's not a bad idea, I've seen the spacers plumbed for nitrous before but I don't have plans for any spray
Old Oct 3, 2015 | 10:11 AM
  #34
terravast4's Avatar
i am running the snow performance kit with a 3 gallon tank in the bed. my butt-o-meter can feel the difference in the upper rpm's
Old Oct 15, 2015 | 09:54 AM
  #35
Y-B-Slow's Avatar
Picked the truck up from Slowhawk yesterday afternoon, 434hp and 419 torque at 12lbs of boost in second gear. Looks like the 90mm tb and J- tube , 1/2" spacer and dropping down to a 2.8 pully all combined was worth a 43hp increase. So no, upgrading the J-tube alone won't get you 30hp. The spacer is keeping things slightly cooler but again bolting on this alone isn't going to result in large gains people are expecting. I was guessing anywhere from a 40-50 overall increase so right about what I was hoping to see. Over the winter I plan to add alky control and maybe a new pully on the crank for a few more pounds of boost but I'm not sure how much faster I should spin this little blower
Old Oct 15, 2015 | 12:21 PM
  #36
terravast4's Avatar
do you have any other mods on that engine?
Old Oct 15, 2015 | 12:25 PM
  #37
terravast4's Avatar
also keep in mind a mustang dyno will see lower numbers
Old Oct 15, 2015 | 05:28 PM
  #38
Y-B-Slow's Avatar
I'm aware mustang dynos generally read a little lower this was also done in second gear for fear of throwing the drive shaft. It only took 8 years of lurking but I think I've made a signature, mods I can remember off the top of my head are listed there. Needs meth!
Old Oct 15, 2015 | 08:08 PM
  #39
TX Tahoe Z71's Avatar
Looks like going from a 3.0" to a 2.8" pulley gave you about a 2psi increase; I'm at 10psi with my 3.0" pulley on my 5.3 with long tubes and GT2-3 cam, and at roughly 15hp per incremental psi, that's 30hp of your 43hp gain. Very surprising the spacer and 90mm TB didn't give you more.
Old Oct 17, 2015 | 12:44 PM
  #40
Y-B-Slow's Avatar
Previously with the 3.0 pulley I was running 8.5lbs so it's hard to say how much the drop in pulley size to 2.8 actually accounts for. At 12lbs now I'm sure the pulley, spacer and tb/j-tube all had some sort of effect on boost one way or another for an overall increase of about 4lbs. If your looking for more I'd skip going 90mm and slap on a 2.8 and some meth.
