5.3 boost and timing
Old May 24, 2008 | 12:21 PM
sdimer350's Avatar
Default 5.3 boost and timing
hey guys im FINALLY going to get my truck dyno tuned on monday. I have a stock 5.3, 4l80e, zo6 cam and springs, and 241 heads which should bring compression down to 9.1 or 9.2-1. custom front mount with mp70 turbo, intercooled. what do you think would be a good boost/timing combo? i want to run 10 lbs and im debating e85(105 octane). I can get it for $2.79 a gal, and prem is 3.99+. any guess on the numbers? thanks
dyno #'s https://www.performancetrucks.net/fo...d.php?t=418618
Old May 24, 2008 | 01:55 PM
Blown06's Avatar
8 Second Truck Club
you running meth? I would be safe and sneek up on it. Maybe start around 15* and add from there. A thing to remember, my truck will handle alot more timing on the dyno than it will on the street because of engine loading. There is alot less engine load on a chassis dyno. Besure when your done to do some actual road testing to make sure it won't knock.
Old May 24, 2008 | 02:02 PM
dirt track racer 81's Avatar
thats why if you do tune it on a dyno do it on a mustang dyno with an eddy current loader to put the actual load on the vehicle..loads are variable depending on vehicle
Old May 25, 2008 | 12:02 PM
sdimer350's Avatar
ok guys thanks for the info. i wont be running meth but will be in the future. i think my tuner said we would go drive it on the street and log some runs. I will let you guys know what the numbers are tommorow
Old May 25, 2008 | 03:31 PM
ZO6Ted's Avatar
15-18 deg.
Choda
Jan 22, 2026 02:03 PM
Raggedz71
Jul 29, 2016 10:20 AM
thunder550
Oct 8, 2015 04:53 PM
elpyro89
Jul 28, 2015 05:51 PM
Gadgetized
Jul 18, 2015 02:15 PM
