motor oil in my S/C intake tube
I took off my air filter to clean it this afternoon, and noticed some oil in the intake tube of my Vortech. I thought it was just dirty water or something, but it's motor oil. I took the rest of the connections apart after the blower and the pipes were clean.
What is going on here?
Mike
Mike
Do You Have A Pcv Connection On The Intake Pipe?? Before The Blower?
Also What Is With All The Oil/liquid Misted All Around In The Pic You Took??? That Could Be An Issue If U Didnt Do It
Yes I do have a PCV connection there. I think I was supplied with a new pcv valve with the Vortech kit. The mist you see is water. I sprayed all of the salt and dirt from the engine compartment.
If you're running the valve cover style pcv system you can swap to an LS6 valley cover. The pcv systems that draw vacuum from the rear driver's side valve cover are notorious for sucking up oil. The LS6 valley cover has an improved oil separator.
http://www.ls1howto.com/index.php?article=18
btw hows thunder550 performance?
