408ci/TVS2300/LSA heads build
Old Feb 1, 2011 | 03:54 PM
  #111
03sierraslt's Avatar
Originally Posted by 1SlowHoe
No cam yet
Are you going to have them run it on a Cam doctor after it is ground? I did with mine, kinda interesting.
Old Feb 1, 2011 | 04:37 PM
  #112
1SlowHoe's Avatar
Destroyer of Transmissions
I thought about it, its only like 10 more dollars for shipping. But no matter what the cam doctor says, it's going in I told them not to worry about it.
Old Feb 5, 2011 | 10:42 PM
  #113
1SlowHoe's Avatar
Default Chevy Orange
I got bored waiting for the cam...
They don't look quite so shiney in person...
Old Feb 17, 2011 | 12:47 AM
  #114
1SlowHoe's Avatar
OK, I was getting things started to put the cam in etc... I pulled the oil pump so I could get my dot-to-dot on. I'm a little confused at the marking on the timing set.
If I put #1 at TDC, the cam gear sprocket tooth at 12 O’clock is -2.
If I set the cam gear sprocket tooth with 0 (Zero) at 12 O'clock my #1 cylinder is already on its way through the compression stroke. Nowhere near TDC.
Now the -2 on the cam gear sprocket tooth is very close to the 0 (Zero) on the numbers closer to the crank (the number the oil pump gear half cover up.
So my question is, what set of numbers am I supposed to use? Did somebody have the original cam in this engine retarded 2*? I'm looking to install my cam straight up so do I set the #1 piston at TDC and the set the cam gear dot to 6 O'clock and ignore the lower timing sprocket or what?
Old Feb 17, 2011 | 11:07 AM
  #115
wkdivr's Avatar
You need to use the numbers on the lower sprocket tooth, not the "body" of the sprocket, if you know what I mean. Can you move the lower sprocket to line up the *0 with piston at TDC by rotating it on the crank snout. I know, if you CAN move it, it has to go to the next key opening. You might want to call the person you bought it from, or the person who built the engine, if they're different.
Old Feb 17, 2011 | 11:13 AM
  #116
Atomic's Avatar
I have a gauge for that
The key in the crank snout should be facing cylinder number 1 when the crank is lined up with number 1 at TDC.
Old Feb 17, 2011 | 11:23 AM
  #117
1SlowHoe's Avatar
That's exactly what I thought. In the first pic under the word "zero" you can see the key at 45* pointing to #1. So I thought 0 should be straight up on the cam gear, not -2.
Old Feb 17, 2011 | 11:26 AM
  #118
Atomic's Avatar
Yea, take off the oil pump drive, and move the timing sprocket over so it has 0 facing up when the key is facing 45 degrees.
As wkdivr pointed out, there are two sets of numbers on adjustable timing sets, the oil pump drive is covering up the bottom set in your case.
Old Feb 17, 2011 | 02:05 PM
  #119
1SlowHoe's Avatar
so what is the correct method to pull the oil drive gear off? I have a 3 jaw puller but I don't see that being much help.
Old Feb 17, 2011 | 02:52 PM
  #120
Atomic's Avatar
That should work...just put something over the crank snout to protect the threads.
