4.8L 80mm Single Dirty Grandpa Truck Build
Old May 28, 2014 | 09:57 AM
  #201
boostedsl2's Avatar
Originally Posted by smokeshow
You made me go out and check mine. All good here!
Got to keep that **** tight son!
Old May 28, 2014 | 10:11 AM
  #202
Atomic's Avatar
I have a gauge for that
Good info there. I use a -6 feed on mine and -10 drain. Never had a problem with smoke.
Old May 28, 2014 | 11:23 AM
  #203
timmay208's Avatar
glad i read this, pretty sure my fitting has a restrictor in it, gonna have to drill that bitch out
I also have 10an return, hope its good cause im not pulling my freaking oil pan off again lol that and im not sure i could fit much bigger where mine is routed
Old May 28, 2014 | 11:25 AM
  #204
boostedsl2's Avatar
I was curious about a -6an. Good to know.
I also seem to see 99% of people running 10 an lines. I'm not sure if i'll change mine to a 3/4. maybe eventually.
I really think my problem is the feed line.
Old May 28, 2014 | 11:26 AM
  #205
timmay208's Avatar
i cant remember if mine is a -3 or -4 feed , guess i better check that out
Old May 28, 2014 | 11:27 AM
  #206
boostedsl2's Avatar
it'll start smoking out the exhaust and you'll start seeing oil consumption if its not sized properly. 10 an is pretty standard.
I think the Diesel guy has a good point and if i were doing it over i might go that route, but i think there is enough setups that have proven 10 an works.
Old May 28, 2014 | 11:59 AM
  #207
timmay208's Avatar
just so much info out there, just read about 10 threads from different forums about it and get 10 different answers
some say -3 straight is fine, others say if you use -4 to use a restrictor. -10 to -12 is most common for the return, so far i havent seen anyone else recommend anything bigger besides what you posted. Gonna have to check my feed line i know my fitting i want to say it has 2mm restrictor which is about .065 i think. I may just bump that up to .080-.090 which from what im reading should be plenty find to supply 30-50psi
Old May 28, 2014 | 12:23 PM
  #208
Atomic's Avatar
You should *never* need a restrictor in the feed, except if you have a ball bearing turbo. If you have a smoking problem, its the drains fault.
Old May 28, 2014 | 12:27 PM
  #209
timmay208's Avatar
I know ball bearing turbos generally require a restrictor. In the import game its very commonly used on both BB and journal due to 80-100psi oil pressure.
Im going to drill my fitting out, i know 2mm is not enough for it
Old May 28, 2014 | 12:36 PM
  #210
Atomic's Avatar
Ah, correct, note added
