4.8 Turbo Build. Need a lil help with cam/turbo.
Old Aug 15, 2015 | 02:00 AM
  #61
03chevytruck's Avatar
Well I need to figure out what gears to get. This is a street truck but building to have fun. Not my DD but will see a good bit highway cruising. I have a set of new 373's that i was going to use but am wondering if i needed 410, 390? I will be running a 28" tires. I've done so much reading my head hurts! not sure what size stall yet(need to contact Circle D still). Currently have a 60e but will be swapping to 80e when the turbo goes on. Oh and i already have a truetrac to install also.
Old Aug 15, 2015 | 02:29 AM
  #62
GMCtrk's Avatar
4.10s will be best for performance, worst for economy.
Old Aug 15, 2015 | 03:23 AM
  #63
Yea I know that but I don't want to regret not going with enough gear. Thought about 456's but i think that's a lil much. I figure settling for 430s should be manageable on the highway. As long as i can manage 2200ish @ 70 mph.
Old Aug 15, 2015 | 11:15 AM
  #64
George C....'s Avatar
Formerly ScreamingL
i ran 488s with a turbo 4.8 before
430s is a good place to end up
Old Aug 15, 2015 | 01:17 PM
  #65
GMCtrk's Avatar
488s was with a t56 to my knowledge. The gearing number is irrelevant without taking into account the transmission ratios.
Old Aug 15, 2015 | 02:07 PM
  #66
Formerly ScreamingL
1:1 is 1:1 in any trans, since we race in high gear as soon as possible it is the same
also as i stated 430s is a good place to be
Old Aug 15, 2015 | 02:17 PM
  #67
GMCtrk's Avatar
You still have to get to high gear, which is the majority of the time spent going down the track.
Not to mention he says it will be doing a lot of highway cruising. 28" tires and 4.30s 4l80 will be running probably 3k rpms at a reasonable speed. Guzzling more gas than me on liquor last nite. All factors need to be taken into accounting, including the fact that not every truck is a race truck driving on the street.
Old Aug 15, 2015 | 02:33 PM
  #68
Formerly ScreamingL
2700 rpms at 70 mph using a 28" tire, swap to a 30" and be fine using a 4l80 on street
Old Aug 15, 2015 | 06:24 PM
  #69
Yes, i should have included that 28" will be track tire. Will run 30ish on street. I know 410, 390, or 373 would be a better street friendly gear but this is not a DD. I might just have to cruise around at 60 mph. I think i will swing for 430's possibly 410's. What would you recommend GMCtrk??
Old Aug 15, 2015 | 06:32 PM
  #70
GMCtrk's Avatar
4.10s or 4.30s as George suggested, in that situation.
Even with the steep gear you should still be able to get 15-17 mpg highway, assuming gasoline
