4.8 compression ratio and head chamber size? How much power?
#22
so how long until the 9.99 pass We know you can do it! Quick question, on the wideband and my factory 02's, should I leave both of the factory ones in place and weld in an extra bung for the wide band before the turbo flange? I'm thinking the drivers side manifold can just be in the stock position right by the flange and the passenger side turbo manifold (building a sorta log style setup) have the 02 bung near the front (since this is the way the exhaust gas will be flowing, does this sound accurate). Should I keep both and add wideband or get rid of factory's and just use a wideband?
#23
#24
Thanks for the info! You think my idea of mounting the stock O2 near the front of the passenger side manifold wil be good? Or should I mount it down near where the stock one would be in the up-pipe from the drivers side
#26
LOL ya I get what you mean. It's going to have a 90 degree upwards with the turbo mount right at the #2 cylinder. So I figured on mounting it right there. Does it matter if the gate is before or after?
#30
Ya I am thinking of running mine by the 90 degree turn up on my log and dumping the gate back into the downpipe as well. Figure that way if anything needs fixn it's easy access Figure a Tial 38mm should hold up fine under 10-15psi on this 4.8
GrooveCityZ71
08-31-2015 12:05 PM
