20psi 180 IAT's =not that fast
#41
Very impressive IAT number for sure. That is very high for sure. It's hard to compare IAT's with others when IAT numbers depend on how long the run is for. If you are seeing numbers in the 180 degree range how low were they when you started and how many seconds were you wide open. Your only similar comparison is Joe's TBSS (365 with big boost TVS2300). How big is the gain in IAT's from a full quarter mile pass (G-tech or other) in Joe's TBSS or on the street a full 0-120 run. If you're way higher than him on a full run like that then you may have some weird cooling issue with the intercooler. You'd have to compare notes/logs with wide open runs and amount of time at wide open/under full boost. Your engine temps going up like that is high for sure. This kind of thing is why I was wondering if you were going to start out at like 12psi with the 2300 and work your way up. Now you don't know if it's much faster at 20psi as compared to 12psi or even 15psi. I think you bought the right blower. I just think you're running it at the wrong boost levels.
#42
Look at your thread and your posts?? You keep trying to put blame on everyone else when you obviously have troubledoing something. If you dont know how to do something and dont want to ask then maybe it would be best to pay someone to do the work for you. I nor anyone else I know is a mind reader. If you dont call and ask a question how do you expect to get an answer? That is about as nice as I can put it.
I haven't really run into anything I haven't known how to do. Mostly its just a time thing. And a little bit of knowing what to do when it came to the tensioner bracket I guess.
You've got a nice TBSS and I'm sure you do great work but when it comes to you I'm moving on.
#43
I had made some runs where the belt came off after the run and my IAT's were in the 130 range at the end so I know its I intercooler or heat exchanger issue. The IC pump runs but I'm not sure if its pushing enough fluid. I'm going to see if I can get it diagnosed tonight.
My GTech run was 11.6 with a 2.3 60' and 127mph on the big end.
#44
When I first assemblied mine it had air in it and I couldn't get it to circulate. You could look and see nothing moving but hear pump working. I took the bleeder screw out of intercooler and applied vacuum to it like you would when bleeding brakes. Once I drew some coolant out it started to circulate.
#45
I have always thought Joe was more of an answer guy. He will sell you whatever you need and has always been there for support. I have sent him countless emails and he always replys. Now sometimes he might get kind of pissy because I flood his mailbox with too many emails and he can't keep up typing but he always helps out in whatever way he can.
#46
Glad he was there to help you. I don't have a beef with the guy. He just isn't someone I'll do business with again.
#47
Wish I would have kept the 1900 and just squeezed a 100 shot on it. Would have had a 10 second truck without all of the b.s. the 2300 has been. To get this setup into the 10's I feel like I'll need a 30% downhill grade.. I should be happy that I didn't loose another belt and/or pulley today I guess.
If anyone is interested I'm thinking of ditching the 2300 and going to a centri. All offers considered
lol
#49
#50
