2012 Tahoe with turbo not making power—Cam issue
Old Mar 28, 2020 | 10:04 AM
  #21
03sierraslt's Avatar
Second sentence in post 3.
Old Mar 29, 2020 | 01:41 PM
  #22
2boosted's Avatar
What timing are you guys running in that area of the curve on 10psi pump gas?
I have a buddy that is street tuning for now until I get back to the dyno. (1.5 hrs away)
were at 9* right now
Old Mar 29, 2020 | 03:23 PM
  #23
madmann26's Avatar
16 degrees should be safe with 93octane.
Matt aka SloppyMechanics provided this gauge eons ago.
The difference in power from 9 to 16 degrees timing should be substantial.
YMMV.
Old Mar 29, 2020 | 04:56 PM
  #24
Take it to 14 and see how it responds, they ease up on it.
Old Mar 29, 2020 | 05:31 PM
  #25
2boosted's Avatar
I agree. This truck is 9.6/1 compression so I think
I have that saved in my phone but it’s hard to show that to someone tuning your car and say, “do this”
I think I’ll try it though. He’s a good buddy so maybe he’ll listen.
Old Mar 29, 2020 | 05:34 PM
  #26
2boosted's Avatar
I like Matt’s videos a lot.I turboed a couple cars because of him after having blower cars.
Old Mar 30, 2020 | 04:11 PM
  #27
wallan482's Avatar
Are you keeping an eye on fuel pressure? I'm not sure what that pump or what the injectors flow, but 400 to the wheels might not be far off for a stock application injector and fuel pump on pump gas. I mean, swinging for the fences, 80lb injectors make what 650-700 on pump gas?
Old Mar 30, 2020 | 04:17 PM
  #28
with enough pump 80lb injectors should support a solid 900 wheel.
Old Mar 30, 2020 | 05:56 PM
  #29
2boosted's Avatar
I have lsa injectors, maybe 56lbers?
mans the flex fuel pump.
Old Mar 30, 2020 | 06:25 PM
  #30
Last Call's Avatar
TOTM: January 2007
The stock LSA injectors should take you to 500rwhp with 58 psi fuel pressure and 11.5 AFR, maybe a little further depending on max RPM.
I would make sure you are not losing boost somewhere, the power essentially flat lines at 4700 rpm, it should continue with an upward slope throughout RPM range.
