2012 Tahoe with turbo not making power—Cam issue
#25
I agree. This truck is 9.6/1 compression so I think
I have that saved in my phone but it’s hard to show that to someone tuning your car and say, “do this”
I think I’ll try it though. He’s a good buddy so maybe he’ll listen.
#27
Are you keeping an eye on fuel pressure? I'm not sure what that pump or what the injectors flow, but 400 to the wheels might not be far off for a stock application injector and fuel pump on pump gas. I mean, swinging for the fences, 80lb injectors make what 650-700 on pump gas?
#28
#29
mans the flex fuel pump.
#30
The stock LSA injectors should take you to 500rwhp with 58 psi fuel pressure and 11.5 AFR, maybe a little further depending on max RPM.
I would make sure you are not losing boost somewhere, the power essentially flat lines at 4700 rpm, it should continue with an upward slope throughout RPM range.
