2 bar map ?? for 2013 5.3
Old Jun 17, 2015 | 01:25 PM
Default 2 bar map ?? for 2013 5.3
Just finishing up a on3 turbo install on a 2013 5.3
after massaging quite a few items & cutting the frame the truck is together & running
went to install the map sensor supplied by on3 & found it requires a different pigtail & the hold down clip won't work
Is there a bolt or clip on map sensor for a 2013 ? I don't care about changing the pigtail but i'd prefer to reuse the clip to secure the sensor
The zr1 sensor looks like it "might" work but I figured I'd ask before buying 1 & finding out it won't
Thanks
Old Jun 17, 2015 | 01:46 PM
George C....'s Avatar
Formerly ScreamingL
zr1 map here in a 2010 intake and its 3 bar
Old Jun 17, 2015 | 02:25 PM
thank you for the reply.
This truck is going to be low boost ( 7 psi ), everything I've read says the 3 bar wouldn't work great with that.. Did you ever have a 2 bar or went straight to the 3? I have hp tuners pro but I don't think the option was there to go up to 3 bar, only 2
What psi are you running with the procharger if you don't mind my asking.
Old Jun 17, 2015 | 02:29 PM
Formerly ScreamingL
you dont even need a map sensor other then stock for the newer pcms. the only reason for the map sensor is to read boost thru the PCM
12psi
Old Jun 17, 2015 | 02:44 PM
12psi
ok thank you
Old Jun 17, 2015 | 02:50 PM
zr1 map pressure sensor part# is 12592525 correct ??
Old Jun 24, 2015 | 09:25 PM
Vortec_psi's Avatar
Correct. I'm also running this sensor on a 2012 5.3.
Old Jun 24, 2015 | 11:07 PM
Jake75's Avatar
12615136 is the 2 bar map im running on my truck...needs a pigtail but works fine
Old Jun 26, 2015 | 09:13 PM
I got the zr1 map, part# listed above, plug & play
Now I just have to sort out the tuning :s
Old Jun 27, 2015 | 06:02 PM
Daniel-lsx's Avatar
augiedog77 You might me asking what were the mods you had to do to fit the on 3 kit on the nnbs
