2 bar map ?? for 2013 5.3
Rs strut mount required trimming the rear bolt & cutting a 3/4 x 3/4" hole in the strut perch to allow the Ls feed pipe on the manifold to clear. The pipe was also flattened quite a bit as well.
The crossover pipe had to be flattened to clear the rs rear front diff frame mount
The swaybar hit the crossover pipe, I still have to resolve this somehow.
Don't cut your upper rad hose or remove the coolant resoivor. I did cut the hose & realized after I didn't have too. I just repositioned the resoivor.
The kit includes heater hose reposition pipes. They arrived after everything else by 4 weeks & I'd already made my own heater hose extensions (ran them beside the battery & out to the thermostat housing
The kit wants you to cut the transmission cooler hoses & reposition it. I found flipping the plastic mounting bracket & reworking the hoses allowed enough clearance.
The 2 bar map they included didn't work for this truck. I bought the zr1 map sensor with the part# I listed earlier
Intercooler only comes with lower mounting brackets that allowed the intercooler to flex into the tranny cooler speed nuts. I made some horrible looking brackets to stop the movement.
Upper transmission line into the rad is right in the way of the turbo for anything air intake wise & had to be adjusted.
The kit doesn't have anything provided for an air filter. That's still to be made up
Moved the ground cable from the rs front of the block to the rear so it didn't have to snake through the turbo manifold/downpipe.
I didn't wrap the manifold but wish I did. Downpipe was wrapped & turbo blanket was installed as well.
Plug wires will rest right on the manifold, I'm using stock wires with heat sleeves, so far it's working. If the manifold had been wrapped & sleeves used there'd be no concern whatsoever about using stock wires.
I removed the pan & had a oil drain bung welded in. Instead of tapping the oil cooler hose mounting plate for feed supply I tapped the oil pan supply to the cooler lines. This is a brand new truck with only 53000 kms on it so no parts were seized. Front diff & steering rack must be dropped for pan removal.
Quite a few splash shields were eliminated due to the intercooler piping. Haven't bolted the inner fenders back in place yet, they might require modification too.
If you do the 2.5 bar os update through hp tuners you must fill in the blanks on the new pids that it enters or the truck will never start & you'll be uber frustrated trying to figure out why lol
I can take pictures of the items if you'd like
Gerry
yes don't replace it with the steel pipes, it's far enough away from the turbo & no piping runs near it.. looks a lot cleaner with the stock hose
Haven't gotten ythe truck back,you haven't gotten it tune, how is the kit
His 19 year old cousin borrowed the truck with the owners permission, no idea what or how it happened but something is blown up @ the back of the intake. Need to remove it & see what's going on once the painting is complete
We need to support USA made products when appropriate.
