2 bar map ?? for 2013 5.3
Just finishing up a on3 turbo install on a 2013 5.3
after massaging quite a few items & cutting the frame the truck is together & running
went to install the map sensor supplied by on3 & found it requires a different pigtail & the hold down clip won't work
Is there a bolt or clip on map sensor for a 2013 ? I don't care about changing the pigtail but i'd prefer to reuse the clip to secure the sensor
The zr1 sensor looks like it "might" work but I figured I'd ask before buying 1 & finding out it won't
Thanks
Thanks
thank you for the reply.
This truck is going to be low boost ( 7 psi ), everything I've read says the 3 bar wouldn't work great with that.. Did you ever have a 2 bar or went straight to the 3? I have hp tuners pro but I don't think the option was there to go up to 3 bar, only 2
What psi are you running with the procharger if you don't mind my asking.
