100mm will not turn!
Old Feb 17, 2008 | 04:57 PM
05crew's Avatar
Default 100mm will not turn!
i have had metco pulley for a long time now and was going to sell them b/c the driver side one when i put it on it does not turn, do i have to grind the back of the bracket for the clearance or may be a washer. i look up on a old thread and got some help but want to make sure.
Old Feb 17, 2008 | 05:28 PM
laynlow77's Avatar
did you get the extra spacer from magnacharger?
Old Feb 17, 2008 | 05:35 PM
BlownChevy's Avatar
blownerator
25 Year Member
The metcos will not work with the new tensioner bracket. Save your money, they do not do much other than look pretty anyhow.
Old Feb 17, 2008 | 07:07 PM
12SEC SS's Avatar
I have metcos on with the new bracket. i just put a small shim under both, took a 3/8s washer and opened up the middle with a unibit, seems to work..
Old Feb 17, 2008 | 08:22 PM
UBLUZIN03's Avatar
off topic- Thats a badass caprice..^^
Old Feb 17, 2008 | 08:46 PM
1Bear's Avatar
I don't know if the bearing offset is different or not between the Metco's and the pullies from Lightning Force, but I have installed two set's of Lightning Force 100mm pullies on two trucks with the updated brackets and have not had a problem one. No shimming or anything else, they just fit. Maybe just lucky?
Old Feb 17, 2008 | 11:23 PM
duwem's Avatar
When I read the thread title, I was thinking 100mm turbo not turning.....
Old Feb 17, 2008 | 11:58 PM
laynlow77's Avatar
i tried mine with the updated bracket as well. ever get me a price on that pin kit?
Old Feb 18, 2008 | 05:22 AM
05crew's Avatar
well im going with a 8 rib set up because my belt is walking off not all the way just 3 ribs. and i dont think the 8rib will work with the stock idlers.
i have two spacers what if i grind off the one the updated bracket and use the spacer ?
can i get the old bracket?
Old Feb 18, 2008 | 07:54 AM
terravast4's Avatar
are you saying the metco's will not work on the 05' and up?
