100mm will not turn!
Old Feb 18, 2008 | 08:27 AM
dewmanshu's Avatar
Moderately Differentiated
Originally Posted by BlownChevy
The metcos will not work with the new tensioner bracket. Save your money, they do not do much other than look pretty anyhow.
I remember when I first started coming around. everybody who started pullying down started whining about belt slip. I gotta say, you don't hear much about it anymore. I flipped mine around anyway, so they are ugly like the rest of my truck. Only practical goes on my truck, not looks.
Okay okay okay, I accidently put it on backwards and then decided to leave it.
Old Feb 18, 2008 | 08:30 AM
BlownChevy's Avatar
blownerator
25 Year Member
They do the same job as a shorter belt would
Old Feb 18, 2008 | 05:09 PM
XLR8NSS's Avatar
Adkoonerstrator
You didn't even know it was on backwards if I remember correctly.
Old Feb 18, 2008 | 06:08 PM
dewmanshu's Avatar
I said accidently. I left the part out that you asked me. I think it is it's gonna stay that way now especially since I had to hack my bracket up. :embarrassed:
Old May 29, 2008 | 07:21 AM
Originally Posted by 1Bear
I don't know if the bearing offset is different or not between the Metco's and the pullies from Lightning Force, but I have installed two set's of Lightning Force 100mm pullies on two trucks with the updated brackets and have not had a problem one. No shimming or anything else, they just fit. Maybe just lucky?
I just tried to install the lightning force 100mm pulley and it touches the alternator bracket or whatever that is.
Old May 29, 2008 | 08:06 AM
leftcoast32's Avatar
FormerVendor
You need the spacers no matter what pulley you use.
Old May 29, 2008 | 11:07 AM
instead of the spacer already there?
Old May 29, 2008 | 03:11 PM
supersub's Avatar
I believe you need one of these vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv vvvvvvv
Old May 29, 2008 | 03:13 PM
FormerVendor
Correct, with these it should clear everything.
Old May 29, 2008 | 04:55 PM
call magnuson to order?
