100mm will not turn!
i have had metco pulley for a long time now and was going to sell them b/c the driver side one when i put it on it does not turn, do i have to grind the back of the bracket for the clearance or may be a washer. i look up on a old thread and got some help but want to make sure.
did you get the extra spacer from magnacharger?
The metcos will not work with the new tensioner bracket. Save your money, they do not do much other than look pretty anyhow.
Originally Posted by BlownChevy
(Post 3851751)
http://ss.lencolab.com/images/painte...8/IMG_0022.jpg |
off topic- Thats a badass caprice..^^
I don't know if the bearing offset is different or not between the Metco's and the pullies from Lightning Force, but I have installed two set's of Lightning Force 100mm pullies on two trucks with the updated brackets and have not had a problem one. No shimming or anything else, they just fit. Maybe just lucky?
When I read the thread title, I was thinking 100mm turbo not turning.....
(Post 3851751)
well im going with a 8 rib set up because my belt is walking off not all the way just 3 ribs. and i dont think the 8rib will work with the stock idlers.
i have two spacers what if i grind off the one the updated bracket and use the spacer ? can i get the old bracket? |
are you saying the metco's will not work on the 05' and up?
