08 Turbo Silverado, and drive by wire throttle body
Old Mar 3, 2011 | 11:43 AM
black98ws6ta's Avatar
Default 08 Turbo Silverado, and drive by wire throttle body
I am having problems with the truck that I built a turbo kit for. It goes into reduce engine power often and most commonly when the truck is on the expressway. I scanned the truck aftwerward to get the cause of the issue and it has codes PO606, PO601, and PO604. I believe all those codes are related to the computer being swapped because the stock pcm was tuner locked. I have heard that the truck throttle body is not strong enough under boost and needs to be switched to the vette throttle body. Any input?
Old Mar 3, 2011 | 11:52 AM
Camaro Zach's Avatar
I had the same issue. 09+ truck throttle body helped and I eventually went with an ls3 tb and have not had the issue since.
Old Mar 4, 2011 | 08:57 AM
Any programming fixes for the problem?
Old Mar 8, 2011 | 06:40 PM
Bump.
Old Mar 8, 2011 | 06:45 PM
2 tuners and help from the HPTuners board.. no tuning fixes at all. The motor in the tb is simply to weak
Old Mar 8, 2011 | 06:50 PM
Cool, is the ls3 throttle body a plug and play? Is the truck you had this issue on forced induction?
Old Mar 8, 2011 | 07:07 PM
smokeshow's Avatar
Mod with training wheels
Thats odd...I don't have that problem at all with the stock TB.
Old Mar 9, 2011 | 11:35 AM
It is hit and miss. I had been using that tb for about 2 years and then one day it started happening.
jdb11386
Dec 3, 2015 09:34 PM
Slammed96
Jul 27, 2015 07:22 AM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
Mzay
Jul 6, 2015 11:03 PM
