05 Catch Can With Or Without PCV?
Old Aug 13, 2009 | 09:28 PM
therock's Avatar
Default 05 Catch Can With Or Without PCV?
Got a Radix on an 05 with the PCV-less system. They stopped using a PCV valve and have a fixed orifice on the passenger side.
Has anyone needed to add a valve inline to the can because of the blower?
Old Aug 13, 2009 | 10:18 PM
KySilverado's Avatar
I have the fixed orifice and a catch can. Works well.
Old Aug 13, 2009 | 11:20 PM
Rick_Vor's Avatar
Same here. Running a catch can off both valve covers and no PCV. Works great.
Rick
Old Aug 14, 2009 | 04:47 AM
therock's Avatar
Great, It's a
"If It's Not Broken, Don't Fix It situation for me.
I have not seen any problems but have been reading on it and wanted to know if anyone else had any.
Old Dec 17, 2009 | 12:16 AM
2005 Silverado's Avatar
SPAM HUNTER
So you guys basically just ran the passenger side stock, or valve cover to intake and drivers from valve cover, to can, to intake.
Old Dec 17, 2009 | 02:38 AM
black00chev's Avatar
Slowest turbo build ever!
Follow the post that this link directs you to for your answer
http://www.SilveradoSS.com/forums/in...dpost&p=683341
Old Dec 17, 2009 | 02:49 AM
SPAM HUNTER
http://www.allensrodeophotos.com/Steve/PCV/OEM-idle.gif
So its a circle, air from intake to passenger side valve cover, through engine, up through drivers valve cover, This is where i will put a catch can, then back to the intake, no more oil.
Old Dec 17, 2009 | 03:32 PM
Mort's Avatar
That may work with a magna-charger but not with a turbo or pro-charger. It will need a one-way valve in the line to keep boost out of the crankcase.
Old Dec 17, 2009 | 03:35 PM
therock's Avatar
As I posted above. OK with the Maggie on my truck for 5 years and no check.
Old Dec 17, 2009 | 04:39 PM
1989k1500's Avatar
Or vent it to atmosphere.
