03-06 procharger kit on a 99-02 NBS
Old Aug 25, 2015 | 09:13 PM
bgray's Avatar
TOTM: June 2007
Default 03-06 procharger kit on a 99-02 NBS
Hey everyone
Just curious is anyone has ran the 03-06 kit on an older Silverado or Sierra. Reason I ask is I hate the placement of the intercooler(down below) on the 99-02 kit. Would rather have it behind the grille in the 03-06 kit
Any incite, or knowledge of if it'll work would be great
Thanks
Old Aug 25, 2015 | 09:30 PM
George C....'s Avatar
Formerly ScreamingL
believe it or not the lower the intercooler the better, youll see a cooler charge down low
but you can install a intercooler behind the grill but it wont be bolt on, youll need to slide rad towards motor some slide ac condenser towards motor some and mod the A-frame
or ditch the AC and place it souly there
Old Aug 26, 2015 | 12:10 AM
Blown06's Avatar
8 Second Truck Club
Last I checked, doesn't the 03-06 kit mount the intercooler down low as well?
I went 10's with that ****. lol
Old Aug 26, 2015 | 09:15 AM
cosb's Avatar
should work just fine.
I did the opposite by putting the older kit on a newer truck and had no problems.
Old Aug 27, 2015 | 07:43 AM
bgray's Avatar
TOTM: June 2007
I thought i remeber reading that the newer kit on an older truck results in cutting the bumper supports or something
Old Aug 27, 2015 | 10:01 AM
Blown06 has it right, 99-06 were all mounted low under the bumper. Only difference between the kits was the bracket in 99-02. Behind the grill was normally a custom job that required cutting A frame. Under the bumper is fine even for a 600-700hp truck, if the temps get to high just add meth.
Old Aug 27, 2015 | 11:55 AM
bgray's Avatar
TOTM: June 2007
Thanks for the input guys!
Old Sep 4, 2015 | 09:50 AM
SuperSlowSilverado's Avatar
Are you referring just to the intercooler or the bracket as well? I have a 99-02 bracket I was getting ready to replace with an 03-06 to use on my 03 but I haven't looked into if anything can be done to use the old style bracket.
Old Sep 16, 2015 | 03:41 PM
E.A.'s Avatar
I run the intercooler in the grill. (procharger unit) and love it.
Honestly, the temp drop seems to be about the same, but my truck is slammed, so I didn't want the intercooler near the 130+ degree road surface we get here in summer, so the grill works for me.
Old Sep 16, 2015 | 07:33 PM
cosb's Avatar
Both intercooler and procharger bracket bolted up with out a problem
chvy=power
Aug 31, 2015 10:51 AM
fiatdale
Aug 26, 2015 09:05 AM
323steel36
Aug 25, 2015 05:11 PM
rebel_within
Aug 25, 2015 11:49 AM
echoman
Aug 22, 2015 01:53 PM
