Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Guess the numbers
Old Nov 14, 2015 | 09:20 PM
  #21
TXsilverado's Avatar
Originally Posted by Fast355
They certainly do have broader torque curve as they rightly should. They have better flowing heads, better intake, and a cam phaser that advances the cam at lower engine speeds and allows it to retard at higher engine speeds.
When I had my Nissan Titans I was amazed how much the phasing of the intake camshafts alone affected the powerband of the engine. The cam phaser moved the intake cams only, 30* advanced from the fully retarded 124* ICL to 94* ICL at lower engine speeds. There was a whole table in the PCM that controlled the phasing with RPM and Load. At part-throttle cruising speeds I found that retarding the intake cam considerably under light loads really helped the MPG. As soon as the throttle was tipped into I found it very helpful to advance the cam to create more torque.
Thought i hid you responses from my view???
Old Nov 15, 2015 | 02:27 AM
  #22
gamble686's Avatar
is it me, or do the newer 5.3 motors seem to have a broader torque curve than the earlier models ? i havent paid attention in a while.
You already know the answer to this one. 243/799 heads, 87/90mm intake manifold that outflows some aftermarket setups, and other small touches.
SixD7
Dec 10, 2015 09:31 AM
AdaMax
Nov 2, 2015 03:57 PM
THUNDERXx
Oct 31, 2015 11:36 AM
Boucher96
Oct 30, 2015 10:00 PM
poundsofjane
Oct 28, 2015 08:56 PM
