Guess the numbers
Shorties dont flow anymore then stock
Cai dont always gain you power
Exhaust doesnt always gain, in some cases loses power
Also many will give you the STD numbers which read higher so reality your not over 300rwhp
When I had my Nissan Titans I was amazed how much the phasing of the intake camshafts alone affected the powerband of the engine. The cam phaser moved the intake cams only, 30* advanced from the fully retarded 124* ICL to 94* ICL at lower engine speeds. There was a whole table in the PCM that controlled the phasing with RPM and Load. At part-throttle cruising speeds I found that retarding the intake cam considerably under light loads really helped the MPG. As soon as the throttle was tipped into I found it very helpful to advance the cam to create more torque.
