2008 5.3 Drive Shaft Vibration!!!
Old Oct 30, 2015 | 11:12 PM
THUNDERXx's Avatar
Registered User
Exclamation 2008 5.3 Drive Shaft Vibration!!!
I have a 2008 Silverado 2wd extended cab V8 with 35k miles on it and i still am wondering what this noise is. Alot of people say its my driveshaft but some say otherwise. When i reach the speed of 95 up in the front of the truck i hear a vibration and i feel it in the steering wheel. It feels and sounds like driving over those rumble strips that are on the highway to wake you up if you are sleeping. Does anyone have the same problem or knows what it is?
Thanks Austin
Old Oct 30, 2015 | 11:31 PM
smokeshow's Avatar
Mod with training wheels
Thanks Austin
I had the same exact truck you have. It was speed governed at 90mph from the factory. Removed the limiter and 95mph had the same vibration. Turned out to be an out of balance drive shaft.
Old Oct 31, 2015 | 12:15 AM
FFDP's Avatar
Guess what brah, you already made this thread a few weeks ago. Maybe you forgot or didnt like the advise then??
https://www.performancetrucks.net/fo...ration-540311/
Old Oct 31, 2015 | 12:17 AM
FFDP's Avatar
Help us help you.
Have you bought another driveshaft yet or atleast had your high speed balanced?
If you have a factory AL driveshaft, you are going to want to swap it out anyway.
Old Oct 31, 2015 | 10:03 AM
THUNDERXx's Avatar
Registered User
It is a one piece aluminum drive shaft and if it keeps vibrating or breaks i am willing to put another one on. I really dont want to spend $600 bucks if it isn't the drive shaft. I haven't gotten it balanced either, but i guess that is what ill do next.
Old Oct 31, 2015 | 11:36 AM
FFDP's Avatar
But when it does break, things go really bad. It can break the transmission housing, damage the underbody and hit the gas tank and brake lines and end up costing you 3x the money to fix it.
All we are saying is that if you want to go at speeds above 90mph, replace the driveshaft before it costs you something more. It might fix your whole problem in the end too.
FlowmasterMufflers
Nov 24, 2015 05:08 PM
rumblebox
Nov 8, 2015 11:15 PM
THUNDERXx
Oct 18, 2015 11:07 PM
djjerez702
Oct 17, 2015 12:48 AM
zeake
Oct 16, 2015 11:13 AM
