Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
eps cam and injector on lq4
Old Oct 23, 2013 | 10:01 AM
tempoffroad's Avatar
Default eps cam and injector on lq4
I have an lq4 that i changed the cam to 222/226 600 lift at 113 i also added 42lb injectors. I have efans from f body and full exhaust with x pipe. truck layed down 353hp at 5500 and 369tq at 4600. this is through a power eating 4l80 and multi disk 3200 circle d converter.
Old Oct 27, 2013 | 06:27 PM
Blackpanther99's Avatar
Not bad at all
Old Oct 28, 2013 | 01:02 PM
Vortec350ss's Avatar
Not bad. I would have thought it made a little more, but certainly not bad! Is that in a single cab short bed? A guy around here with a very similar cam and truck just went 12.4 in some fantastic weather and a 3600 converter.
Have you ever had it at the track?
Old Nov 2, 2013 | 05:02 PM
ShredSled's Avatar
Was that pull in 3rd?
Yeah if he can hook I'd imagine mid 12's shouldnt be difficult. Those OBS are quite a bit lighter too.
Old Nov 2, 2013 | 06:15 PM
03sierraslt's Avatar
I would've expected it to make peak power higher than 5500. Are you sure you're fuel pump wasn't giving up at high rpm?
Old Nov 6, 2013 | 09:51 AM
I run a 255 pump. Its a long bed but truck is complety gutted of everything. I have not been to the track yet
Old Nov 6, 2013 | 05:31 PM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
what track would you run at?
Old Nov 7, 2013 | 12:36 PM
i plan on running at piedmont november 17th you should come out. I just ordered a set of mt et drags so i can hopefully get some good times.
Old Nov 10, 2013 | 11:23 PM
BLKSSLTT's Avatar
I would but I'm taking a trip to nj that weekend.
Old Nov 12, 2013 | 05:08 PM
Ok just give me a shout when u want to go.
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
jaypowe11520
Jul 29, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
NuckenFuts
Jul 9, 2015 08:45 AM
