Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Couple dyno questions
Old Nov 27, 2007 | 01:17 AM
TravisH's Avatar
Default Couple dyno questions
What gear should a dyno run be done in? I see 3rd gear alot but im afraid I'll be going about 150 on the top of 3rd with 35's and 3.42's lol. How does it affect it if run in 2nd gear? Also, should the converter be locked or unlocked? what will the differences be?
Old Nov 27, 2007 | 02:58 AM
jakebdb56's Avatar
I don't know anything about the converter, but for gear selection if you have the aluminum driveshaft most shops won't dyno it in 3rd.
Old Nov 27, 2007 | 04:00 AM
Spoolin's Avatar
GFYS and STFU
Locking the converter will give you higher numbers. Aluminum Drive shafts will come apart at like 130 mph wouldn't recommend doing it. A member on here was recording his dyno runs when his driveshaft gave way. Wasn't pretty and it took out most of his truck in one swoop. Do 2nd gear pulls.
Old Nov 27, 2007 | 08:49 AM
WJ MARK's Avatar
we couldn't get mine to read second for some reason. Had to get into third past the point where it wouldn't down shift.
Old Nov 29, 2007 | 11:05 AM
dkota1968's Avatar
I made a run in second and one in third, Heres the results(this is my old truck):2nd gear-284.5hp/285.25tq, third gear-267.37hp/292.1tq. That was on a dynojet. Seems like the tq will register higher in third and hp lower. Third gear gives you that 1:1 ratio to your rear axle if im not mistaken. I was doing like 145mph, crazy looking when the stock 265/70/17 tires bulge out.
Old Dec 2, 2007 | 01:56 AM
jakebdb56's Avatar
you know you can lock into a certain gear with HPTuners scanner
GXPJAY
Feb 13, 2022 08:15 AM
Noah Burns
Sep 7, 2015 05:50 PM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
FlowmasterMufflers
Jul 9, 2015 12:23 PM
