TIME SLIP DATABASE
results, well sorta......
Old Dec 15, 2008 | 03:48 PM
  #21
454navyss's Avatar
Originally Posted by vanillagorilla
I drove on a broken piston for a year and a half. It'll spray oil and be down on power, but you can still drive it. Depending on where it broke, your cylinder walls might be fine too.
What was your race weight? Your spinning might be pinion angle related. What angle did you wind up with? I thinkg a little preload on those long bars will go a long way.
his race weight is around 3900 i believe.
im curious what your 1/8 time was too
Old Dec 15, 2008 | 07:44 PM
  #22
silver-mod-o's Avatar
Hunt&Fisherator
Ill have to look at the slip when I get home but I believe it was an 8.0 or maybe even in the 7s
I didn't do much weight reduction, just the backseat and tail gate, I didn't even think to put it on the scales.
Old Dec 16, 2008 | 08:23 AM
  #23
454navyss's Avatar
the way it sounds like your run was going it should have been in the 7s
Old Dec 17, 2008 | 10:25 AM
  #24
Hunt&Fisherator
Here's the full slip.
60'----- 2.100
330'-----5.382
1/8------8.012
Mph------91.89
1000'----10.186
1/4------12.511
Mph------110.87
When its back together, a LOT more emphasis will be placed on getting the truck to 60' better. This was its first real run on 28" GOOD slicks too, I'm sure I'm a lot of the error too. I need just as much practice as the truck does.
Old Dec 17, 2008 | 11:40 AM
  #25
99Silverado5.3's Avatar
You were not kidding that 60 sucks...but started to move nicely almost 92 at the 1/8th would had you right there @ 11s. Was that 6psi pass?
Old Dec 17, 2008 | 12:12 PM
  #26
454navyss's Avatar
if the 5.3 wold have held with some track time and tuning i bet you could have run a low 11, maybe faster
Old Dec 17, 2008 | 01:34 PM
  #27
buzzkillwill's Avatar
Man, sucks to hear about the motor, but it sounds like it's time was up...
Old Dec 17, 2008 | 03:56 PM
  #28
Hunt&Fisherator
Yep, just 6psi and pump gas, no meth, no nitrous.... If I had mixed the 110 in there maybe she would have lived going lean....
Like I said, the emphasis will be on the 60' this time back together. The power will be there (and then some) to run DEEP into the 11s and maybe faster. I have no doubt it would have gone 11s that pass or the next. The 60' just kicked the e/t in the ***.
I'm almost tempted to throw a running 5.3 in it just to see how fast I can go with it I doubt ill ever find one thatll hold up under the punishment this one took. this motor will be missed.
Old Dec 19, 2008 | 09:05 PM
  #29
sixltrbtr's Avatar
Well I don't think it was the way the suspension was setup that caused it to spin... The track was just slick as hell... And I honestly think the car ahead of me dripped some crap... No excuses though. Once its back together ill see about adjustments. I had them built with opposite threaded rod ends so I can adjust the length/preload. I just ran them as is just to see... I don't think I got near enough heat in the slicks either.
Don't forget how cold it was.. The track was probably cold especially if you were one of the first to run that day!
kainzien
Nov 10, 2023 11:37 AM
Cha_Feel_
Sep 23, 2015 09:06 PM
FormulaZR
Sep 14, 2015 05:23 PM
fastjweb
Sep 1, 2015 11:21 AM
dselby25
Aug 24, 2015 07:26 PM
