TIME SLIP DATABASE
New PB 05 crew cab 12.90 at 107.8
Old Feb 20, 2011 | 07:34 PM
fastjweb's Avatar
Default New PB 05 crew cab 12.90 at 107.8
went to the track today in my quest for 12's. Above 5000 my injectors are at 122% so my shift points were set to 5500 and max boost is 5 because of it. Time slip goes as follows, totally stoked to get 12's with such a **** 60 ft and not being able rev her out, but hey i felt safer.
.293
2.035
5.436
8.328
85.1
10.74
12.90
107.8
Still waitin on some mickey thompsons so im spinning bad, not being able to stall. ran with the 20's up front and stock 17's with nittos on rear. Full wieght, subs and all. heres a vid of my run against a fox body
http://www.youtube.com/watch?v=BYaagtE7bfw and heres a 12.98 at 106.6
http://www.youtube.com/watch?v=i2_COsJDzFg
Old Feb 20, 2011 | 07:58 PM
NORTH TEXAS TBSS's Avatar
formerly NORTH TEXAS TBSS, then slowgibbs, and now back to NORTH TEXAS TBSS :) (2012-05-27)
Nice times! Time to update the sig
Old Feb 20, 2011 | 08:31 PM
fastjweb's Avatar
thank you, hope to get some tires and get some 1.80s and see what it will drop to.
Old Feb 20, 2011 | 08:33 PM
skeet's Avatar
very nicely done!! get some full slicks, throw some smaller rims/tires up from front and really drop the ET
Old Feb 20, 2011 | 08:35 PM
jpodell's Avatar
That's f'n quick. And change your sig.
Old Feb 22, 2011 | 07:02 PM
fastjweb's Avatar
changed the sig, thanks for the comments
Old Feb 26, 2011 | 03:08 PM
KDavis04ss's Avatar
get some bigger injectors and move them shift points up and go deeper into the 12s. thats a badass crew cab man.
Old Feb 27, 2011 | 10:16 AM
Jake99's Avatar
The 2-3 shift sounds a bit slow in the vid, if thats slip that 60e wont hold up long.. But shes running strong, with slicks and injectors you will be deep in the 12s..
Old Feb 27, 2011 | 01:51 PM
fastjweb's Avatar
its not slipping, the trans is set for a 32" tall tire for my 20's and i was running 26" nittos so it was jackin up the shifts pretty good. Thanks for the comments, i hope with a set of 28" MTs on some 16" rims and the injectors ill be able to get low 12's. my fastest 60 ft was 2.03, and i couldnt stall it.
Old Feb 27, 2011 | 01:57 PM
skeet's Avatar
dang, you got that heavy hauler moving!! congrats
projectnightcrawler
Sep 30, 2015 10:49 PM
abey15
Sep 25, 2015 09:30 PM
bluebommer07
Sep 20, 2015 08:42 PM
fortune46x
Sep 16, 2015 08:18 AM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
