TIME SLIP DATABASE
leaf spring Hilux drag racing launch help?
Old Sep 15, 2012 | 07:02 AM
AussieHilux's Avatar
Registered User
Default leaf spring Hilux drag racing launch help?
Hi guys,
Took my 4x4 dual cab to the 1/8 mile last Sunday and had all sorts of trouble getting it off the line.
It's a 383 stroker running just under 20psi through a built th700r4 and 2,500 stall. 4.56 gears and 31 inch tyres.
Running stock leaf springs and shockies all round.
What do i need to happen to make the truck hook up ?
No sticky on the track.
ran a 2.4 second 60 ft and 92mph at 8.63 1/8 mile.
any ideas?
here's a you tube vid of the truck:
I don't really want to go much faster in mph but i do want to get better 60 ft times. what do i need to do to the suspension to launch harder?
Old Sep 15, 2012 | 01:44 PM
silver-mod-o's Avatar
Hunt&Fisherator
Are you spooling the turbo up and leaving in boost??
Old Sep 15, 2012 | 06:21 PM
Registered User
I'm just idling at the line with foot on brake and then stabbing throttle about halfway on the last yellow light at the same time taking my foot off the brake.
Then flooring it at about the 60 ft mark.
Old Sep 15, 2012 | 06:36 PM
Hunt&Fisherator
You need to be spooling the turbo in the lights... We need as much information about the combo as possible, turbo sizing, cubic inches, compression, converter, gearing weight etc...
Old Sep 15, 2012 | 06:55 PM
ak2007r6's Avatar
Right now by just stabbing it off the line you probably starting to build your boost as you cross over the 60'. Like mentioned above spool that turbo up when you launch. Being 4x4 you should hook pretty decent.
Not sure how much that flat bed weighs but that might be one downside is you have very little weight over the rear tires also
Old Sep 15, 2012 | 07:17 PM
Registered User
The car is a toyota hilux 4x4 dual cab weight 4500lb
I have a iron holden v8 block (5Litre or 304ci) stroked to 383 ci
3.75 inch stroke, 4.035 bore
5.7 inch chevy rods
diamond racing 350 chev pistons (the forged blower ones with 22cc dish and 1.5 pin height. 4.035
The pistons are an oddball and down the hole 0.040
all balanced internally with come racing crank. (no mallory needed)
holden vn Iron heads 59cc chambers. 1.60 exhaust and 1.94 intakes.
cam: come racing csbh462,
218/222 @ 50 112 degrees .491 valve lift intake and exhaust. hydraulic flat tapper.
9.5/1 Compression
come racing twin throttle body manifold
water to air intercooler (1000hp)
chinese To4b-11 turbo (wheels sizes unknown) 0.70 ar 1.15 rear
water and oil cooled (marketed at 800hp turbo) (pcpa website)
50mm wastegate and blow off. 3 inch dump pipe.
20psi boost
factory ignition.
0.020 plug gaps NGK bpr6efs
moddified factory ecu (delco 808) real time tuning capable with full dual maps tuned at home with wideband and tunerpro software.
80lb siemens daka high impendance injectors at 11.50 afr under boost
running 98 octane with octane boost.
0-100 kpa timing map is locked at 28 degrees advance and reducing 1 degree for every 10kpa boost. (this side of the tune is all guess work probly needs more timing?)
GM th700r4 auto rebuilt at home with the "pro street elite rebuild kit" from dana at probuilt automatics in usa.
2500 approx stall made by accelarator in Australia (garanteed to take 1000hp)
4.56 diff gears toyota hilux 8 inch and lsd centre
31 inch mud tyres. (tried a set of 28 inch road tyres and got more mph but traction was harder to find. put muddies back on.
standard toyota hilux leaf springs all round and standard shokkies.
Old Sep 15, 2012 | 07:18 PM
Registered User
That tray is very heavy... havent weighted it but 3 blokes can't lift it.
Old Sep 15, 2012 | 07:20 PM
Registered User
I have full controll over the ecu... what's the best way to tune it for boosting off the line?
There is dual maps available and I have a button on the shifter that can immediately switch between maps so I could try retarding spark and go rich before launch to spool up? hows it done?
Thanks
Old Sep 15, 2012 | 07:32 PM
Registered User
launching in 2wd. The front drive shaft is home made(needed clearance for auto) and I don't trust a 4x4 launch or the drive hubs for fear of steering me off the track if something brakes.
Old Sep 16, 2012 | 11:05 PM
Registered User
Does anyone here have any ideas for me with regard the suspension setup for my truck to get the weight transfer to the rear on launch?
Have stock 6 leafs in the rear and stock shokkies all round.
I have enough hp for how fast i want to go just can't get it down off the start how it is setup right now.
What do you blokes have in the rear to help the leaf springs ? do you take leafs out or add more?
C'mon men, I'd appreciate some tips please, next meet is in November and I can't go any faster untill I figure out what needs to happen in the rear of the car. I'm heading down the path less traveled over here so not much local advise is available to me here.
I'm stuck at 2.40 60ft times.
